1968 Jaguar 420 chassis mount separated
Hi Folks
I should have supported the front crossmember after removing the wheels and suspension,question is (the mount is in good condition albeit separated)can they be glued(superglue)or is it possible to rebond with heat.I dont know but I would think back in the day they would have used heat before some of the hi tech adhesives that we have today,any advise most welcome.
Best Wishes Dan Gardner
Received 1,488 Likes
The mounts are cheap to replace and I now check and replace mine on a regular basis. As Glyn referred to I had an engine mount separate on tick over. The fan on the front of the engine destroyed my radiator as the engine moved sideways by only half an inch.
The front cross member mounts are £26 each to replace at SNG. https://www.sngbarratt.com/English/#...ush%20front%60
Engine mounts you can get for as little as £11 each compared to over £500 for the radiator to be re cored. https://www.sngbarratt.com/English/#...ine%20mount%60
Peter3442 (05-06-2024)
The following 2 users liked this post by my420:
Glyn M Ruck (05-06-2024),
Thanks for sharing your experience .I had no idea how vunerable these engines were to movement.I hope they gave you some compensation.
Best wishes Dan Gardner
Alexsandiego
04-30-2019 01:45 PM
MK2
04-05-2015 09:26 AM
