3.4s over run when switched off.
Received 1,437 Likes
Thanks Glyn, done all that. I love the fact that Jaguar have put all these adjuster parts in to the throttle linkage but you can't get to any of them when they are in situ.
The double spring has brought the throttle return right down so it sits at 600 now with no need to pull the pedal back but I am waiting for the weather here to clear up so I can go out and get the car hot to test the run on or lack of it.
Playing with the throttle linkage return it does seem too stiff with the kickdown attached. Fine it I disconnect it so I might have to take the cable out and give it a good soak in oil and a clean as this might be why the throttle is not closing fully.
Glyn M Ruck (08-21-2020)
One would think so. Suck, blow, bang. The number of times I have said to someone having problems starting a car that all you need is air, fuel, combustion and a spark. I have taken away the spark by switching the engine off so my problem must lie with the air, fuel or combustion.
One would think so. Suck, blow, bang. The number of times I have said to someone having problems starting a car that all you need is air, fuel, combustion and a spark. I have taken away the spark by switching the engine off so my problem must lie with the air, fuel or combustion. 9:1 ratio pistons might not be helping on the compression side. A throttle that is not closing properly might be a cause for the air and fuel.
In the late 1960 I worked as Ford Service rep and the Ford Cortina was renowned for running on so much so the only way to stop the engine was to put in gear and let out the clutch.
Ford brought out a kit to stop it happening. It consisted of a solenoid connected to the ignition system and a vacuum hose connected to the brake booster vacuum supply. With key on and engine running solenoid was closed key off solenoid opened and a large gulp of air stopped the engine. The solenoid even came with a very neat small air filter.
David Bruce. Australia.
No, but you CAN shut the ignition off while leaving the transmission in D. That results in an immediate shut down. My 3.8 will run on under very high heat conditions, after a high speed run with the AC on - but if I leave it in D and turn off the ignition, it shuts down instantly. If the above-mentioned conditions are not present there is no shut-down issue at all....well that is true, BUT if I leave the car sitting for a half hour after a run, it is reluctant to start, and I have not figured out why -any comments on that? I have assumed that it is a matter of heat sink anf fuel vaporization.
#30
#31
The instantaneous start when cold/cool is always impressive...the slow start after heat soak isn't impressive at all.
#32
A lot depends on the gasoline used and it's distillation curve. Too many light ends in the gas will cause this. Oil companies tailor gas for ambient conditions. e.g. they make at least summer grade & winter grade in places with large temperature swings. Use of winter gas in hot conditions is almost guaranteed to suffer vapourisation. I have zero hard hot start issues here in CT with our gas & mild climate. Canada is obviously blending gas erring on the safe side for cold conditions. We have plenty of family in Canada. My Dad was Canadian. Difficult country to decide on gasoline blends with it's temperature swings.
Heat shield/under bonnet ventilation is the only answer. If you have a Kenlowe or similar fan fitted maybe you can put a time delay on it so it runs for a few minutes after shut down.
