3.8 correct ignition set up
There is a massive amount of misinformation on line regarding the ignition set up of a 3.8 liter Jaguar engine. I am doing a complete ground up restoration of my 1962 Mark 2 and like a fool removed the old DMBZ6A distributor before checking distributor rotation. I will be installing a new 123 ignition distributor. With very little specified info in the official Jaguar Service Manual, here is what I gleaned so far from various sources:
No 1 cylinder at rear of engine near cowl
Firing order 1 5 3 6 2 4.
Distributor rotation counter clockwise
Can anyone confirm this.
Confirmed, and you may make #1 on the distributor which ever one you want as long as the firing order is maintained, but with out checking I think Jaguar says the closest terminal on the distributor cap to the block is #1.
What is different for many of the models is the actual ignition timing, it varies depending on what pistons are used in relation to the compression ratio, I think it says in the manual.
I have my 340 set at 6 degrees before top dead centre and I have 8:1 pistons.
farina43537 (06-02-2024)
Hi,
From the 3.8 S-type shop manual, (and the "operating handbook") : Engine number... Stamped on the right hand side of the cylinder block above the oil filter, and at the front of the cylinder head casting. /7, /8, or/9 following denotes compression ratio.
On my car its also on the body plate directly above the back of the engine on the firewall. Good luck!
csbush (03-31-2016)
