3.8 Engine rebuild
#261
Yes, quite a lot of oil mist escapes via breathers in all engines, which is one of the reasons that designs with catch cans have an attraction but may be difficult to make work. The plenum in the series 3 fuel injection intake is a low point in the intake and easily collects half a pint of oil. Fortunately, it doesn't upset the engine running too much.
#262
#263
A flexible breather line will let you vent engine to atmosphere, closer to the ground below your motor. You will get a messy oil film all over the side of the engine with your current configuration.
https://mossmotors.com/jes-8234-cylinder-head-breather
Rgds
David
Rgds
David
#264
If you're not going to a more sophisticated system with a PCV (one way valves, catch can, etc), the ideal is to have the breather exit at or a little below atmospheric. Then, there's no pressure pushing oil out through crankshaft seals and the like, and not too much flow through the breather carrying out oil mist.
#265
The following 2 users liked this post by jayd2:
David84XJ6 (08-18-2024),
Peter3442 (08-18-2024)
#266
to do it right, it looks like i'll need to route it back to one of the two new air cleaners i've installed. i think a plastic tube and fixing hardware for the tube was provided with each air cleaner. a hose of proper ID and two hose clamps should do it. if stout enough the hose may not need support...could i be so lucky?
Glyn M Ruck (08-18-2024)
#267
Cut bottom of breather pipe at 45 deg. with long side forward, to create slight low pressure area at breather exit (I would not add the filter). With the exit below the engine you will have sufficient airflow. The length of the breather pipe is sufficiently long that you will have to trim it to fit.
Later "smog" cars vented breather to the back of the air cleaner(s) to burn blow-by fumes, unfortunately this introduced blow by oil into the intake system and made a mess in the carbs. I added a $25 eBay universal oil catch can before filters on my XKE. This is pure environmental, no benefit to engine or performance. I assume since you now understand it's a jaguar engine, you have the obligatory "oil drip pan" on you garage floor.
#268
Received 1,476 Likes
#269
#270
First Oil Change
I just completed the first oil change. The oil filter paper pleats inspection was good, it was very clean with minimal contaminates on the paper pleats. This engine has the downward facing oil filter, you must allow the oil to flow back into the pan to get an accurate level check. With 6 1/2 quarts the oil level is in the middle of the Full area.
#271
First Engine Rebuild - Completed
This was my first engine rebuild, it was worth the effort. The engine is running great and I got to experience the rebuild process.
The Moss 4 speed with overdrive was also an interesting project. It had to be disassembled, cleaned and inspected, then reassembled. There were some issues but they were easily resolved.
Peter3442 (08-21-2024)
jayd2
07-10-2024 09:50 PM
Charles J. Edward
34
06-10-2024 09:13 AM
