3.8 Engine rebuild
#121
My Lucas data base shows:
Both 3.4 & 3.8 CR 9:1 1966 Jaguar with 22D6 # 41064A distributor, with a {5/12/8} vacuum unit.
Give these guys a call, for recommendations on best distributor specs, for your compression ratio and fuel octane available.
They can overhaul and update your distributor for your planned configuration/application.
British Vacuum Unit
Canterbury, NH 03224
(603) 731-1788
For orders or info, use our web "Contact Us" or email us direct at
https://www.britishvacuumunit.com/lu...ibutors-1.html
This thread addresses some options:
https://www.jaguarforums.com/forum/x...xj6-s2-250183/
Rgds
David
British Vacuum Unit
(603) 731-1788
Rgds
David
#122
Received 1,452 Likes
8 to 1 CR = Lucas 22D6 ~ 41063A ~ on all 3 of the cars I had to restore my S Type. Monster Lucas Data Base .pdf that is too large to attach here shows the same. Seems the different CR has a different advance curve. (Another Service Manual mistake)
#123
#124
There no vacuum ports on the intake or carbs. I prefer not to drill any holes to add a vacuum port. Unfortunately, I haven't found many distributors without a vacuum advance. Mechanical advance only distributors have a different advance curve.
Is there a specific reason why some engines came with mechanical advance only?
#125
( Tailored advance curve for optimal performance and drivability)
Amazon price $285.00 Added matching coil Pertronix 45011 Flame-Thrower II 45,000 Volt 0.6 ohm Coil , Black price: $62
or (a Lucas DLB198 ignition coil, price $42 Moss Motors)
Note: you must use Electronic Ignition spark plug wires. Any Parts store can supply correct wire sets, if you ask for 1984 XJ6 S3 jaguar wire set.
I have not heard anyone comment on this unit, many Jaguar owner are happy with the Vacuum advance version. I installed Vacuum version on my 1968 XKE and it worked well. The Lucas distributor I removed was non-vacuum; It was a smog distributorto deal with lean burning at all RPMs, and like the carburetors were made to be tamperproof.
Rgds
David
Glyn M Ruck (05-05-2024)
#126
My Moss 4 speed has a what looks like a threaded hole in the top cover. The manual shows a small dipstick in the exploded view of the gearbox. Is this hole for a dipstick? Did they all have a dipstick? There is a threaded hole in the side of the main case for a plug, I assume that you fill the transmission to that level.
#127
#128
I've been researching oil for a Moss 4 speed. It's a little confusing, some say it must be a GL4 oil, all GL4 I've found is multi-weight, like 80w-90 gear lube. Other's have stated not to use multi-weight oil. Moss sells Redline MT-90 for manuals. Some post state specifically not to use synthetic oils, Redline is a full synthetic oil.
What is a proper lubricant for a Moss 4 speed with white metal?
#129
#130
#132
#133
#134
#135
#136
I'm looking for spark plugs for a 3.4. It's bored .030 with a "B" type head, 8:1 compression and 2 SU HD6 carbs. What would be the correct heat range for 88-91 octane fuel? Champion shows a heat range from 6-9 for engines with a "C" type head, no listing for a "B" type head.
#137
My 3.4 is bored .030 with a "B" type head and 2 SU HD6 carbs. Are there several cams that can be used with a "B" head? Is there a significant HP difference between the cams? I've seen 3.4 HP ratings from around 160 to over 200HP. What's approximate HP range with the "B" head?
#138
#139
David84XJ6 (05-10-2024)
#140
The power ratings then were gross, not net like is used now, and some of them were rather optimistic. I have tested my 3.8 with an actual compression of 8.6 and I measured 164 hp.
Some of the XK120, Mark VII, XK140 and Mark 1 2.4 had 5/16" lift cams, and the later engines all the way to 1992 has 3/8" lift cams. An engine from a Mark 1 3.4 should be 3/8" lift.
Glyn M Ruck (05-10-2024)
