3.8S questions
Glyn M Ruck (09-21-2021)
As Jose has stated the S type was always Positive earth or ground.and had a generator not an alternator. The 420 which shared a lot of its parts with the S type and was built during the same period (S Type 1963 to 1968, 420 1966 to 1969) was negative earth and fitted with an alternator.
If you want more specific details about the S type we have a forum dedicated just to the S Type which can be found at THE INTERNATIONAL JAGUAR 'S'-TYPE REGISTER FORUM - FORUM INDEX
There is also a register of S Type Jaguars run by the same forum so we can keep a track of thoses that are left and have lots of information regarding individual cars which might have been supplied by previous owners if your car is already on the register.
Here's the instructions I used to re-polarize my S type. It is so simple it's like duhhhh. Sure you should get a new battery that was charged Negative Ground from new:
https://starautoelectric.com/instruc...ing-generator/
Whether the frame of the car is connected to the positive side of the negative side should make no difference to the battery and just because that is changed around, should make no difference to the battery.
I'm still using the same battery on my car after I changed to negative ground, or moved the negative terminal to the frame of the car.
The following 2 users liked this post by JeffR1:
Cass3958 (09-22-2021),
Glyn M Ruck (09-23-2021)
Received 1,488 Likes
During the discharge of a battery, the current in the circuit flows from the positive to the negative electrode/terminal. According to Ohm's law, this means that the current is proportional to the electric field, which says that current flows from a positive to negative electric potential. Electrons are what flow in the reverse direction.
Battery charge is irrelevant. No need for a new one.
Polarise Lucas Dynamo/Generator at the RB340 Lucas Voltage Regulator. RB340 Right.
S Type RB340 ~ Mk2 is similarly mounted but on a pressed bracket.
Hi Peter,
Thanks for asking but no I am not. As I said in the OP, I am trying to increase my knowledge of the S-type. I don't own a S-type but at some point I would like to own a 420 and since the 420 is built from the S-type there is a lot to be gained by educating oneself. I feel that the 420 and the S-type are under appreciated by the Jaguar community as a whole.
Glyn M Ruck (09-22-2021)
The 420 had a lot of upgrades over the S type. Bigger brake discs and calipers. Dual circuit brakes. 4.2 engine rather than the 3.4 or 3.8 in the S. Different gearbox which was actually an older model being the Model 8 Borg Warner but stronger to take the extra torque from the 4.2. Less wood but more emphasis on safety as the dash top was padded. Negative earth and an alternator whereas the S Types were all positive earth and had the generator. Power steering on the 420 was the Adwest Marles Variomatic which was fitted to the later S Types and powered by a different PAS pump. Other than these upgrades the two cars were the same mechanically just had different front wings and grill.
the MK-X, S type, 420 and 420-G have styling elements of each other, inspired by the MK-X that started the low wide styling..
the XJ of 1968 is essentially the inflated 420-G to which they let the air out. It can also be said the XJ is a flattened 420.
As to replacing the battery or not. I was told it was good practice to replace it when converting to negative ground and I did. Besides my old battery had the poles in the wrong sides so it had to be replaced anyway.
The following 2 users liked this post by Jose:
Bob Hornby (09-25-2021),
Peter3442 (09-24-2021)
Jose (09-24-2021)
Durableoilcom
05-04-2011 06:00 AM
