340 Front Seats
340 Front Seats
I just finished a do it yourself carpet install in my 340. Actually looks decent for a home job. I have re installed the front seats and had forgotten about an issue that I had noticed before. The drivers seat back is tilted farther back than the passenger seat. I don't know how the mechanism on the backs is suppose to work. It looks like the backs tilt whenever the seats slide back and forth, Attached is a pic of my seats installed. I have a spacer under the rear runners on the drivers side to try and take up some of the tilt. No matter where the seat is the back leans to much for my preference. Any thoughts?
Received 1,432 Likes
Everyone is shying away from this and I'm not sure I can help other than a bent seat. I note the seats are not of the reclining variety.
Out of interest some S Types had this configuration of seat fitted. Are yours the original seats other than upholstery pattern? The S Type armrest could easily be covered up by a pro & the seat reprofiled.
Quote:
"Each seat was mounted on a unique fore-and-aft adjustment mechanism. Instead of the conventional sliding runners, this used swinging links that lowered the front of the cushion and raised the rear as the seat was moved forwards, and vice versa."
credit James Taylor
Whether later 340's saw this mechanism on their bucket seats I don't know either. Another possibility.
credit James Taylor
Peter3442 (03-29-2023)
Glyn M Ruck (03-28-2023)
The following 2 users liked this post by hueyhoolihan:
Glyn M Ruck (03-28-2023),
I have only seen one car so equipped in Thailand of all places. Taylor does not describe it well. It still has slotted floor runners but includes swinging links that lowered the front of the cushion and raised the rear as the seat was moved forwards, and vice versa.
that would explain it...but mean that the seat backs will only line up when the seats are set at the same distance from the toeboards. and THAT will not due at all for the many compulsives out there (you know who you are) that must orient all their strings beans side-by-side, on their plate, before eating them.
Glyn M Ruck (03-29-2023)
Yes Indeed Huey ~ You are spot on. ~ Why I started with bent seat unless something has gone cuckoo in the mechanism. Worn clevis pin etc. It is the most used seat in the car.
I should add a wink ~ ~ for the **** which I'm inclined to be as a typical Virgo.
See here on repair job ~ seems backs come loose on non recliners ~ in 1968 this is a 240 ~ same seat as 340 ~ deleted tray/picnic tables:
https://bridgeclassiccars.co.uk/clas...guar-mkii-2-4/
Mk2/340 non adjustable.
Received 1,039 Likes
The following 3 users liked this post by Bill Mac:
