67 MK 2 restoration
Old 02-21-2017, 10:35 PM
gene61jag's Avatar
Originally Posted by TilleyJon
Gene61,
I wish I had a huge workshop and all the fabrication tools, but I don't, so we all improvise, adapt and enjoy the journey.
It's true. I haven't welded yet, but I have "JB-Welded"
  #102
Old 02-27-2017, 02:52 PM
csbush's Avatar
After much procrastination, I finally got back to the bodywork. I cut out the rusty areas, fabricateda multi-piece curved patch, and welded it in.It isn’t beautiful, but it is solid, won’t leak water, and is rust free.(It will be beautiful after furthershaping and painting) I also finishedwelding in the tire pan.I am startingto get a better feel for the welder and made a lot better progress.
I also learned the technique of heating upthe metal with a torch and stretching it into place with a hammer so the fit is correct for welding.I have never used this before because I didnot have a acetylene torch but found that the Map gas torch you can buy in ahardware store works as well for heating and bending metal.
I also did a little body work with lead. There were two small dents on the rear by the boot latch that I didn't have accessto pound them out, so I filled them with lead.My technique is getting better and I am very happy with how they cameout.
So it was a successful day, and now I am energized to tacklethe seat pan!
Pictures will follow when this tool lets me. IT is being uncooperative today.
gene61jag (02-28-2017)
  #103
Old 02-27-2017, 03:21 PM
TilleyJon's Avatar
Progress indeed, pics when the IT works please sir.
Take a look at Lazze metal shaping on you tube, that man is astonishing, some really interesting stuff, and you can pick up some ideas. I just wish I had a small amount of his talent.
csbush (02-27-2017)
  #104
Old 02-28-2017, 12:18 AM
gene61jag's Avatar
Hey Chuck, great to hear you're making progress on your tire pan. Sounds like you're done with that part?
I agree with Jon - Lazze is awesome to watch
  #105
Old 03-03-2017, 11:07 AM
csbush's Avatar
After leading.
before leading
Finally able to post some pictures
  #106
Old 03-03-2017, 11:10 AM
csbush's Avatar
Patch complete and tire pan in.
Some photos of the tire pan work. Patch is complete, and it is finally in, just need to do a little more grinding.
  #107
Old 03-04-2017, 03:18 PM
TilleyJon's Avatar
That's a tricky job done, good progress.
  #108
Old 03-07-2017, 10:06 AM
gene61jag's Avatar
That's beautiful Chuck!
csbush (03-08-2017)
  #109
Old 03-08-2017, 04:33 AM
redtriangle's Avatar
Looks pretty solid!
csbush (03-08-2017)
  #110
Old 03-08-2017, 01:20 PM
csbush's Avatar
Ready to go!.
Playing with the upholstery. Center console is done. It isn't as pink as in the picture!
The following 2 users liked this post by csbush:
lickahotskillet (03-08-2017), tedwone (03-24-2017)
  #111
Old 03-08-2017, 11:16 PM
lickahotskillet's Avatar
Sharp!
Did you have a template/old piece to copy for the shifter boot?
  #112
Old 03-09-2017, 06:54 AM
csbush's Avatar
The parts came as part of an upholstery set. The shift boot was already cut and sewn like that. I don't have the old one as it had disintegrated. I could probably come up with some rough measurements if you need it.
  #113
Old 03-09-2017, 07:49 AM
CS,
Thanks. Just rough height is what I need. Don't have a shifter shaft at the moment.
  #114
Old 03-10-2017, 08:14 AM
csbush's Avatar
The shifter boot is about 6 inches tall. About four inches protrude from the console. It is wide enough at the top to allow the thickest part of the shifter to fit through it, and it is about 16 inches around on the bottom where it is folded over and tacked under the console.
TilleyJon (03-10-2017)
  #115
Old 05-08-2017, 08:35 AM
csbush's Avatar
Rust repair with rusty metal removed- ready for welding.
Had to create an inner panel from stock steel as both exterior and interior layers were rusted out. Not beautiful welds, but much improved with the new welding wire.
Welded on the repair panel from SNG Barratt
Leaded over the repair to seal it, and fill lower areas. Now only need high build primer.
Been a while since my last update- because I haven't have not been doing much work on the car- but finally got back to the welding. Swapped out the .030 wire I had been using for .023. That seems to work much better for the body panels. I am getting much better and smaller welds with less heat distortion. Have had to do very little grinding of welds and with a lower temperature setting, wasn't burning up he metal and blasting holes that then needed fixing.
I now have only one more corner patch to make, and a few holes in the floor pan that need repair. Then it is just paint stripping and sealing. I should be able to start on all the mechanicals this summer
  #116
Old 05-08-2017, 12:34 PM
TilleyJon's Avatar
Nice to see you have managed to get some more progress, it takes some time to get those awkward bits done.
Best advice I can give you is to get a couple of cans of weld thru primer, it will help protect areas like seams against future rust in areas that you will cover with other patches. If you can clean more of the surface rust away from the weld area either with a wire wheel or a blaster it will help with the weld splatter too.
Keep up the good work, thanks for the pics.
csbush (05-08-2017)
  #117
Old 05-08-2017, 12:58 PM
gene61jag's Avatar
Sweet! Good to see those side panels getting restored. I will have to do the same thing soon.
  #118
Old 05-08-2017, 01:02 PM
csbush's Avatar
Yes- I am a fan of the weld through primer, and use it on the panels before I close them off. I also use body cavity spray, and get it up in the enclosed areas too.
That is very helpful about the weld splatter- I didn't realize that was causing it.
  #119
Old 05-08-2017, 01:54 PM
TilleyJon's Avatar
Glad to hear your into the weld primer, just didn't see it in the pics, so mentioned it.
Weld spatter can be caused by contamination and also incorrect setup on the mig, first make sure the work area is really clean, if you are still getting spatter, reduce wire feed rate or increase voltage, if the wire is not feeding into a molten pool you will get spatter, also caused by being too far away with the torch, on thin panels it is a very fine line, to get enough penetration to weld the joint properly the metal must be molten, slightly too far and you blow a hole !!! Oh the joys of welding these little gems ?
The following 2 users liked this post by TilleyJon:
csbush (05-08-2017), tedwone (05-08-2017)
  #120
Old 05-11-2017, 01:17 PM
gene61jag's Avatar
I have a couple of cans of that weld-thru primer also. I need to get some body cavity spray though. I don't want to give a place for the cancer to grow back.
Quick Reply: 67 MK 2 restoration
