Advice ~ protective decal removal boot/trunk lid handle/no plate lamp/reverse light
Received 1,486 Likes
The chrome trunk handle was NOS in it's original box. It was/is covered by a pink tinted clear protective decal. This thing is 50 years old & the decal won't come off. Using a finger nail you can chip tiny bits of it off. I don't want to scratch the perfect chrome. Any advice on removing it? I've been told everything from a heat gun to WD40. Anybody have advice or experience in this regard?
A heat gun is too hot, use a hand held hair drier held really close if you want to go that route.
It has to be held in one place long enough to soften the adhesive so the decal will peel off.
Start with an edge and work your way through.
Using a hair drier may leave a sticky residue that WD40 will remove.
Basically anything oil base will soften the adhesive so it can be worked off.
Paint thinner can be used.
What will dissolve the old decal for sure is lacquer thinner or acetone.
This won't hurt the chrome, but will eat the paint.
You could try Goo Gone, it is supposed to work wonders and is surface safe.
You could try panel wipe, it won't affect the paint at least. The plastic cover is the hardest to remove, the glue can be removed fairly easily once it has the plastic protection gone !
Olive oil is supposed to work too, but you need to leave it for several hours to soften stuff up, you could soak a rag and leave it on over night to see if that works, that also won't affect the paint or chrome, and you may well have some to hand, Diesel may well do the same thing, it should soften the plastic if left on for a fair while.
FS[SouthEast]: XK XKR XKR-S boot lid trunk hatch filler trim panel & LED plate lights w/camera mount
jahummer
02-24-2018 01:51 PM
slojotaa
F-Pace (X761) / C-X17
06-03-2016 06:19 AM
