ADWEST Power Steering
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have been experiencing problems with the ADWEST power steering so am intending to have the steering box refurbished.
I have checked the pump on the rear of the dynamo, replaced the seals and renewed the cam set and pegs and had all the high and low pressure pipes renewed.
The steering box has been isolated as per the Service Manual page 327 (Section I.s.7) – no problem.
However I don’t seem to be able to then “withdraw from beneath the car (the box)” as indicated in the manual. The box seems to be, in effect, wedged between the main chassis side member and the oil filter head. As you know the box is quite a heavy casting and not that easy to manipulate. I am wondering if there is a knack to manoeuvring it out that has so far eluded me!
An alternative would appear to be to unbolt the off side engine mount and carefully lift the engine up a few centimetres with a bottle jack and wooden batten placed across the sump pan. However, this is itself rather a potentially risky procedure when you are lying under the vehicle so want to avoid it if possible.
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
If the box is wedged between the chassis and the oil filter head and you only need a few centimetres, then removing the oil filter housing should allow you to remove the box ???
I had to remove my power steering box, but my car is a left hand drive, so it was easily removed from the top.
Your brake booster/carbs are in the way.
Just thinking _ what about unbolting the front sub frame, you wouldn't need much clearance, you could probably leave the front brake lines connected.
Block up the sub frame, take the weight of the car off of it, undue the bolts and continue to raise the car until you have enough clearance to remove the box, being carful not to stretch the flexible brake lines.
Even removing the brake lines isn't big deal, gravity bleeding the front calipers is pretty easy.
Thank you both for your prompt and helpful replies. The suggestion by JeffR1 has also been made by some other contacts in the Jaguar Enthusiasts Club including someone who works on these "old" Jaguars for a living. On the basis that there is no substitute for having done a job as opposed to what the manual states, I will go with the suggestion of unbolting the sub frame.
All the very best for a happy and positive 2017. We are looking forward to a great Hogmanay tonight here in Scotland!
Hogmanay _ had to look that up.
While Canada is not even 200 years old, I always find it fascinating to find traditions that have been celebrated for centuries in other countries.
The Wiki on this quite interesting.
We have our parades and all day foot ball (boring), but nothing like that.
And not to forget excessive drinking and drunkenness (embarrassing).
The town I live in consumes twice the annual level of alcohol when compared to other towns of the same size population.
New Years just gives people even more of an excuse to drink more and be an annoyance.
https://en.wikipedia.org/wiki/Hogmanay
You have a great Hogmanay !
![Icon Toast](https://www.jaguarforums.com/forum/images/smilies/icon_toast.gif)
Sharpractice (01-02-2017)
The following 2 users liked this post by TilleyJon:
lickahotskillet (01-04-2017),
