air intake plenum connection to carbs on mk2
Old 08-14-2024, 03:41 PM
David84XJ6's Avatar
If it has a "paper" media element as well you should be fine.
K&N filters have good reputation... I used 3 K&Ns on XKE triple carb manifold.
https://mossmotors.com/222-955-chrom...-su-1-3-4-deep ...shop around, you may find a cheaper supplier.
Rgds
David
Old 08-14-2024, 04:25 PM
Jagboi64's Avatar
Received 3,191 Likes on 2,104 Posts
Depends on who you ask! Years ago on the Jag lovers lists, one of the members was a professional mechanic and ran a small race team. He built a pair of identical engines for the season, and equipped one with a K&N filter and one with an OEM paper filter. Everything was measured and recorded in the build.
When the engines were torn down after racing, the one with the K&N had measurably more bore wear than the one with a paper filter and higher silica in oil analysis, indicating that the K&N's allow a lot more dirt into the engine than a paper filter. His conclusion was that K&N's only kept out "boulders".
The following 3 users liked this post by Jagboi64:
Cass3958 (08-15-2024), Glyn M Ruck (08-16-2024), Schmitty (08-15-2024)
Old 08-14-2024, 04:37 PM
Glyn M Ruck's Avatar
Received 1,476 Likes on 1,147 Posts
K&N is a typical example of poor filters other than those made for them by Mann to Mercedes Spec in blown polyester in Germany.
With K&N it is generally pure marketing. Purple rubbish.
The following 2 users liked this post by Glyn M Ruck:
Cass3958 (08-15-2024), JeffR1 (08-14-2024)
Old 08-15-2024, 02:25 PM
David84XJ6's Avatar
I was contrasting the pancake foam filters, verses the K&N .... other manufactures don't make filters for one off short filters for SUs with tight space requirements. I am in agreement, if you do weekend figure 8 racing on a dirt track, you might want the best filter available.
Rgds
David
Old 08-15-2024, 04:42 PM
K&N do not make good air filters. I'm a Tribologist for a supermajor Oilco & we have tested them all.
The standard Jaguar OE filter is vastly superior or if you use quality filters like Mann.
Taurox
07-16-2023 02:57 PM
otokar
03-28-2022 09:00 PM
kevh
01-14-2021 09:08 PM
jagent
06-01-2016 05:42 PM
Justink201
04-03-2015 10:09 AM
Quick Reply: air intake plenum connection to carbs on mk2
