Annoying Fuel Filter Gasket Problem
Thanks for that George.
Came across this re-usable brass one _ interesting !
https://www.musclecarsandclassics.ca...er-gf-124-1958
While the paper filters were not supplied by Jaguar they did supply a filter (still not sure what it was made of) via a tech bulletin in 1968. In the bulletin they offered that retrofit was permitted if not suggesting it was desired. The issue with the screen is all is trapped on top of the screen. With the proper filter the crud goes to the bottom of the bowl. filters with a spring on the bottom are for V12 cats and are not proper as those filter in the wrong direction. Here is an original 1968 on filter.
Interestingly I can't find that filter in the UK, did they use a different one here ?
Re the gauze screen, this only filters the fuel on the way out of the bowl, the idea being it trapped the debris on the way out to the carbs and when no fuel is passing the crud can drop to the bottom of the bowl, there should not in theory be any crud on top of the screen.
Tilly I will look up the TB but the screen that came with pre 68 cars actually filters toward the carbs. The center hole is "IN" and the screen is "Out". That was reversed on the V 12 cars so the longer filter with the spring was correct for them but NOT for six cyl cars--of course some have gone to the trouble of reversing the lines--instead of obtaining the correct filter. Tilly a quick search of E bay UK found this https://www.ebay.co.uk/p/ACDelco-Gla...75.c100623.m-1 As Joey and I said they fit many things --try a petrol powered tractor supply co.
Thanks George, let me know re TB, may have misunderstood re the screen, you said crud gets trapped on top of the screen, if the centre hole is IN (which I agree), then fuel goes directly into the glass bowl, and exits up and through the screen to the carbs, catching the crud under the screen, as the top side if towards the carbs.
Thanks for the link, it's still from the US and cheap at only $100 delivered ! I will do a search for the part number to see if I can find an equivalent here.
I have never studied the flow direction for the paper filters, I will have to take a look when I get a moment
Tilly take a look at this--it explains it well. The comment re: filter not available was toward the bunt cake type. The paper replacement is avail everywhere.
Fuel Filters
Fuel Filters
#30
#33
Thanks George, found it now, under General - Bulletin No5 April 1969
I have all the TB's for SS Cars and Jaguar up to 2009 together with the parts and service books, but not always easy to find certain specifics.
Still not found a supply in the UK that doesn't want £40 for a filter !!!
I have an old school agricultural parts stockist nearby that may be able to help.
Jhuntbatch
02-19-2015 08:26 AM
Roach169
08-22-2011 07:47 AM
