Annoying pinking/pinging noise
Old 07-29-2013, 12:03 PM
Hobbsy's Avatar
Default Annoying pinking/pinging noise
Starting from cold my 3.8 auto engine has a pinking type noise which stops once car at full temp.
sounds as if it's coming from rear of engine
Any suggestions please
Update on this problem
have checked timing and it's fine
repaired slight crack in manifold.....noise still there
drastic action next i think...i'm going in
Old 08-01-2013, 03:25 AM
Hobbsy's Avatar
Lightbulb
still desperate for any input/suggestions from members
Old 08-01-2013, 08:36 AM
GGG is offline
Received 16,861 Likes on 12,186 Posts
I'm dragging this up from the depths of memory going back many years.
As far as I can recall the 3.8's would pink with poor quality fuel and this could be corrected or at least minimised by retarding the ignition. Apart from being annoying, the risk is local hot spots on the piston crown which can eventually cause failure. Our fuel quality in the UK is generally OK although I tend to steer clear of supermarket filling stations after a couple instances of poor running on a modern V8.
Even in the 60's and 70's, head distortion was an issue and skimming quite commonplace to restore a flat mating face. This, of course, increases the compression ratio and makes the potential for pinking even greater. Forty years on and your 3.8 could have been skimmed to the point where a thicker head gasket or a sandwich plate is needed to restore the correct compression ratio.
You mention a cracked manifold. Is the repair completely gas tight and the manifold mating face absolutely flat?
Old 08-07-2013, 05:26 AM
Hobbsy's Avatar
thanks for the advice will be looking into it
crack in manifold is sound
compression is down slightly so looks like may need thicker gasket
thanks again
JimC64
31
05-30-2016 03:04 PM
Rocky15
10-12-2015 03:42 AM
jospolice
10-02-2015 07:16 PM
inactualis
10-02-2015 11:13 AM
baskervillema
10-01-2015 06:43 PM
Quick Reply: Annoying pinking/pinging noise
