Any cure for my shaking rear view mirror
Jaguar is a 1959 Mark 1. Inside rear view mirror hangs down with a ball /socket arrangement that allows adjustment to the desired position. My problem is that the mirror will NOT stay in the desired position, but will get cast downward very quickly giving me a nice look at the rear passenger seat. Also, this mirror will shake so much that its impossible to really focus on anything one sees in it. Any way to add some stabilizing compound (superglue ?) to this ball / socket arrangement ? It appears that the socket could possibly be pinched in slighly to add some gripping power, but I'm reluctant to do so for fear of breaking off the connection entirely. Not to mention its near impossible to work on because the windshield is very close.
Thanks for your thoughts !
Schmitty
Schmitty
not sure this will be any help, but...
the rear-view mirror in my 1967 Mk2 was doing pretty much the same thing. upon disassembly i discovered the problem was that the threaded collar that tightened the brass choker around the ball was partly stripped and wouldn't tighten down completely. i used a bit of teflon tape to support the threads and got it tight enough to do the job....barely.
even the car dealer's service department where i bought the car couldn't figure it out. although, i doubt they tried all that hard...
Received 1,486 Likes
As I recall, the MK2, S type, and 420 all have the same mirror arrangement. There's a small, sort of triangular plate that is attached to the roof by 3 screws that go through the roof lining. A rod is screwed into the bracket at one end and attaches to the mirror by a ball joint at the other.
Mine was OK up to 80 mph and then would vibrate like crazy. I think the rod isn't very stiff and has no damping. Fortunately, the image in the mirror didn't move as much as the mirror itself and, in those days, I didn't bother to fix it. I'd guess the options are to add some weight or damping or, perhaps best of all, lightly attach the rod to the windscreen with some rubber. It shouldn't need much to calm the vibration. It might also stop the mirror slipping on its ball joint.
I was thinking of a small rubber disc (a slice from a stopper or some washers glued together) that makes a firm fit between the rod and the glass held in place by a dot of adhesive. For the ball joint, I don't remember how it's arranged, tighten it mechanically or insert some tape (PTFE?).
I'd attributed the shaky mirror in my car to a resonance rather than limitations on ride quality. It appeared at a little over 80 m/h on smooth surfaces. If the S type and 420 don't suffer from the problem, it might be a resonance excited by the prop shaft or something in the body structure. If/when the rebuild is done, I might find out more.
