Ash tray removal.
The one on the dash should just slide out and then there is a metal tab in the middle at the back which stops it from coming right out. Push the tab down with your finger tip and the ash tray slides out.
The two in the back are easier. Lift the roll top, stick a finger in the ash tray and pull. The ash tray comes out of the holes and underneath are two screws which hold the casing to the door card.
Hope this helps.
The following 2 users liked this post by Cass3958:
Glyn M Ruck (07-12-2022),
ppsales (07-12-2022)
Which ash tray are you referring to?
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Cass3958 (07-14-2022)
