Auto transmission fluid level
I'm guessing your 340 has the BW12 unit. If so, shift pattern will be PRND1D2L.
The car has to be warmed up and at idle as per factory manual below:
If you have the dreaded DG250 box, there are 2 dipsticks to check (also in the factory manual & handbook).
I swapped my DG250 for the later XJ6 BW65 unit which fortunately shows the fluid levels (both hot & cold) on the dipstick.
This is not correct, surely. My 1966 3.8 has the DG250 (why "dreaded"?) and has just the single dipstick in the engine compartment. Are you perhaps thinking of the earlier cars which had the dipstick in the cabin under the console (miserable to access)? If the car has the later engine compartment dipstick, that is the only thing that needs to be checked.
Perhaps I am wrong, but I assumed the later cars had the BW12 or type 35 tranny.
Barry,
I believe my rear mount is off an XJ6. I will try an get a photo for you.
It is much simpler than the original mount, but did necessitate drilling fresh holes in the floor pan.
The dipstick was a pain. Had to do some judicious bends to get it in the restricted space in the transmission tunnel. I have not attended to the upper fixing mount as yet.
I also note there is a breather tube for this particular tranny, which I have replicated. It attaches to the dip tube at the top. The breather bung on the end of the breather tube is still obtainable from Barratts (rather exp. at 13 quid for a bit of plastic!).
Lastly, the oil pan still leaks despite numerous gaskets, sealers etc and attempts. Very annoying. The original gasket is useless (squeezes out when tightening the bolts) and I suspect the leakage occurs around the bolts themselves, perhaps thread sealer will do the trick.
barrymk2 (04-24-2016)
Did you manage to get a photo.Ive been told that the exterior of an bw65 and 35 are same. manage to source a bw35 rear mount. Tried to compare measurements , difficult, but look similar. No room to work in current garage, so will have to wait until weather changes
Perhaps you could describe your mount, is it a square frame with 2 rubber sandwich blocks, this is what I have used, suspended using original angle iron DG mout. Barry
Thanks Pete,I am very much obliged for pic.The mount that I have sourced looks remarkabley like the one pictured, I was told it was from a BW35 mk2!!!!!
Been talking to a jaguar breaker( car not CB) he says there are 2 types!!!. Suggested I take some measurements and he would advise.He says they have different mounting holes to one another.
How different were the holes you made?
Baz
Baz
Pete,
Some measurements of the part in my possesion, 4.5" between slot(holes) centres, 8 1/4" from centre of rear hole to centre of spigot. The distance between your slots seems marginally smaller than mine, can only guess with a pic. Mine has cut out at the front, spigot end slope, on RH side.
Baz
PS seen the post on the ZF box?
Baz
Amelorn
24
02-11-2016 01:58 PM
