auxiliary starting carburetter
Hello, I went to start my Dad's old Jag yesterday as we tend not to use her in the winter and I like to keep things ticking over. Foolishly I did not wait for the fuel pump to stop ticking before I started her up like I was taught to do. I have recently replaced the fuel pump and thought that the new one might work a bit differently?? She did fire up but then there was fuel all over the garage floor. This had been coming from the auxiliary starting carburetter.
Is there something just sticking that just needs a dismantle and a clean or is there something that need replacing?
Thank you
Harry
Thank you
Harry
As Fraser said, did you replace the fuel pump with the correct SU type ?
If it's the correct fuel pump, check the float bowls that the floats are still floating, and that the needles haven't stuck.
It's a process of elimination, do you know the SU carbs well enough to take them apart somewhat ? We can help, but best to know what level of expertise you have.
Jon
Jon
mystype04
11-20-2010 07:12 PM
