Battery bracket rubber
A simple question, I think. There is a rubber strip that attaches to the bracket that holds the battery in place. I assume that is just glued to the metal bracket? If glued, is it cut in the corners or just pushed into the bracket corner as far as it will go?
For some reason, I have two rubber strips. One is older and seems to fit on the bracket very nicely. The newer rubber seems to be too narrow. It's as if they found an extruded rubber material that was "close enough" and sold that as the bracket rubber. The bracket is after market, too, so maybe that is the issue.
Thanks in advance
Craig
Thanks in advance
Craig
Received 1,476 Likes
Glyn M Ruck (07-29-2024)
Argh! They only have 1 in stock
https://mossmotors.com/catalogsearch...keray%20washer
David Manners found mine.
https://www.abingdonmgparts.co.uk/pr...A--mgb/ajd7731
