Bolt thread question
I decided to remove the rear suspension and have been instantly confronted with a problem. The bolts that are safety wired and hold the safety strap to the front of the radius arm need to be replaced. Barrett says they are 7/16 - 20 UNF. Does anyone know if that is correct? They were partially stripped upon removal so I want to re-tap the captured nuts in the mount. I did check and they are 7/16 - 20 but my thread gauge is SAE so don't know the thread angle. Before purchasing a tap to clean up the threads I want top make sure I get the correct one.
SAE stands for "Society of American Engineers".
So find 7/16 fine thread on your gauge - U.N.F (union national fine) or 20 TPI (threads per inch) and that will be correct.
SAE _ UNC/UNF don't use thread angles like the metric system, it's just threads per inch.
There is an angle to threads, but I don't know what the standard is, but it's not measured that way anyway.
Get a tap tap that says 7/16 20 UNF.
If there is room, get a "taper" type tap, it will be easier to start as apposed to a "plug" or "bottoming" type tap.
If there's not enough room, then go with the plug type.
Received 1,455 Likes
As a general rule on these cars, any thread into steel will be fine thread, anything into aluminum is coarse thread. You see coarse in studs into the cylinder head. The SU carbs and fuel pump along with Dunlop brakes are Whitworth/ British Association thread forms, everything else is SAE fasteners.
Peter3442 (Today)
Received 1,050 Likes
It is my understanding that Jaguar went to SAE threads (UNC and UNF) with the introduction of the MK7 in 1951.
This was to satisfy the American market which was at the time their main market. Lyons had done his homework on gripes over servicing previous models.
The previous MK4/5 series were full of the old BSF, BSW, BA which were a pain to work on with different spanners etc.(I did have a MK5)
Not every part made the transition as suppliers like Moss, SU, Lucas etc. still clung to their old English thread systems.
However, any parts manufactured by Jaguar in the 1950s and 1960s should use SAE.
I can't speak for the later car series as I have found metric creeping in.
For even more pedantry, the thread forms are SAE and Unified National, and within those exist fine and coarse thread standards. Thus UNF means a Unified National thread standard, Fine series.
The Unified National came from an agreement in 1949 between the USA, Canada and the UK to adopt a standard common to the three countries.
Once major difference is that UN/SAE fasteners always have an exact fractional head size, or AF (across flats) designation. For example a 5/16" shank diameter bolt will always have 1/2" across flats head, BSW does not do this. The wrench for UN series fasteners, which is most common wrenches and sockets, always uses the across flats designation. Thus a "half inch" UN wrench (spanner) is 0.5" between the jaw of the wrench. BSW uses the fastener shank diameter, thus a BSW "half inch" wrench actually has a jaw opening of 0.920".
Johnny V
06-21-2018 06:51 AM
LeapingCat
Mark V - X 420G
02-22-2014 12:39 PM
scyzoryk
07-25-2011 03:33 PM
Currently Active Users Viewing This Thread: 9 (1 members and 8 guests)
