cam drive dog
Old 11-09-2013, 06:05 AM
Hobbsy's Avatar
Default cam drive dog
Hi
anyone know where i can get a replacement cam drive dog
have tried Manners but they no longer stock this part, not sure if this is correct name but it's the small round part that attaches the rev counter to the back of the cam
thanks in advance
Old 11-09-2013, 06:37 PM
JeffR1's Avatar
You mean this ?
Part search results from David Manners Ltd - C25426
Here at xks.com if this is what you need.
http://partsxks.com/i-7080899-co-254...r-plastic.html
Here is the other part as well.
http://partsxks.com/i-7080357-co-167...ric-tacho.html
David Manners says he has this as well.
Hobbsy (11-10-2013)
Old 11-10-2013, 03:52 AM
Hobbsy's Avatar
Originally Posted by JeffR1
You mean this ?
CO-25426 - Drive Dog Tachometer; Plastic
CO-16771 - Adaptor Fitting Rear Of Cam; Drive For Electric Tacho.
Thank you for that we must have a lazy salesman
will order one in morning
Old 10-19-2020, 10:17 AM
hdrop's Avatar
Default replacing cam dog
Good day to all forum members,
does anyone has the answer to how to remove the drive dog so that it can be replaced by a new one.
Thanks in advance
regards,
Hans
S Type 1965, 3.8 l
Old 10-19-2020, 11:14 AM
Glyn M Ruck's Avatar
Received 1,478 Likes on 1,149 Posts
Rev Counter Generator
Adaptor that screws into cam.
Plastic dog that fits into adaptor
If its just the plastic dog you need to replace remove circlip & fish it out with a screwdriver & push in a new one & refit circlip.
Old 10-19-2020, 12:11 PM
Excuse my building this post in bit's & pieces while finding pics.
Old 10-19-2020, 12:12 PM
hdrop's Avatar
Hi Glenn,
didn't notice that your answer was in 2 reply's .
I will try to pry the dog out whit a screwdriver as you suggested
thyanks
Hans
Last edited by hdrop; 10-19-2020 at 12:16 PM. Reason: didn't notice that your answer was in 2 reply's .
Old 10-19-2020, 12:16 PM
Sorry we posted over one another. See my post above. You need to use circlip pliers or just a screwdriver if circlip actually fitted has no holes.
No Churchill tool I know of. Someone might have a better suggestion on circlip removal.
Old 10-19-2020, 12:18 PM
hdrop's Avatar
Glenn
Thanks again.
Greetings
Hans
Glyn M Ruck (10-19-2020)
Old 10-19-2020, 12:30 PM
Working at the back of the engine with a mirror can be a pain. My car's circlip in that location has holes for circlip pliers.
Old 10-19-2020, 12:45 PM
Churchill tool 18G 1004 works well with the 90 deg. points inserted--but any circlip tools with 90 deg will work.
Old 10-19-2020, 02:23 PM
hdrop's Avatar
Thanks,
I'm going to crawl on the engine with a mirror and hope to see a circlip with holes. ;-)
Old 10-19-2020, 05:14 PM
Presume that is no help with the older standard Jaguar Circlip with straight ends & no holes? I've never seen any tool for those darn things.
But will work with this type circlip with holes as fitted to my engine? As will most 90 deg inner/internal circlip pliers.
Old 10-19-2020, 07:39 PM
cdg66mk2's Avatar
On a related note, is the tongued drive supposed to slide in and out? Mine will "snap" back into the generator housing if I push it in. It spins freely and does not feel any different than if I pull it back out and spin it. Its almost as if there is some sort of detent that allows it to be in one of two positions; in or out.
Thanks!!
Old 10-19-2020, 10:35 PM
sov211's Avatar
Received 2,272 Likes on 1,371 Posts
Thanks!!
you have found the problem: the "tongued drive" is not supposed to retract back into the generator. If it does, it disengages from it camshaft drive. I had to have my tach generator replaced last year for this very common issue.
Old 10-20-2020, 04:24 AM
hdrop's Avatar
SOV11,
There is a circlip to hold the the tongued drive, zie picture.
Old 10-20-2020, 10:05 AM
hdrop's Avatar
This is how the drive dog is secured so it's probably the original one.
Old 10-20-2020, 10:28 AM
Yes that is the original type. Hope you can prise it out with a screwdriver or similar.
This is the replacement:
Old 10-20-2020, 10:38 AM
hdrop's Avatar
Thanks,
already in the basket at SNG with new seal for the generator and the drive dog.
Glyn M Ruck (10-20-2020)
Old 10-20-2020, 10:55 AM
Great! Good luck with reassembly.
Quick Reply: cam drive dog
