Daimler Ds420 no crank.
Hello!
Trying to get my friends Ds420 to start. It has an automatic gearbox and is from the later half of the 80:s (87?!), can't remember at the moment. It's a right hand drive and when turning the key nothing happens besides two relays click. One behind the dash some where on the right of the steering wheel and another somewhere to far to the left behind the dash or maybe in the engine bay. When trying to crank I have either park or neutral in gear while pressning down on the brake. Further than this I haven't troubleshot.
The thing is that with fuel injected cars I know a bit. With the carburated cars I know almost nothing so some tips would be much appreciated. Where to start? What does car "want" to start? Usual things that fail and should be checked?
/Dave from Sweden
/Dave from Sweden
On the DS420 there is no brake interlock, so no need to hold the brake. If it doesn't crank the first place is to check the battery, both the battery voltage and capacity itself, and then check the cables to the battery. Are the terminals clean and tight?
If there is a relay click that says the ignition switch is working, my bet is a weak battery.
Received 1,481 Likes
I presume the engine is not frozen so check it rotates with the plugs out and a spanner on the crank pulley nut. As stated above check the starter motor is not frozen by putting a jumper lead straight on to the power terminal on the starter.
If both these rotate freely then look at earth cables and earth points on the body are not corroded.
Glyn M Ruck (07-11-2021)
B-rad
04-10-2018 07:12 PM
RayJak
07-29-2012 08:25 AM
