Dipstick tube removal
I nearly have my engine stripped to the bare block and ready to be boiled out and machined as necessary. The dipstick tube is still in place and it is not obvious how (or if) it comes out. I have been hitting it with penetrating oil now and then. It does not seem to want to screw out. I would rather not mangle it since its probably not obtainable. Any suggestions?
Its a late '66 3.8 liter.
Thanks!
Thanks!
Received 1,434 Likes
Had a problem with mine a year ago when the dipstick snapped leaving the bottom end jammed in the tube. The tube is a press fit.
I removed it simply by heating the block with a hot gun then I pulled the tube out with mole grips. In my case the dipstick provided something solid in the tube for me to grab hold of but I am sure with a little persuasion with heat and a gentle pull the it will come out.
Fitting it back in I put the tube in the freezer overnight and then heated the block up with the hot gun and the tube slid into place with the tap of a piece of wood and a small hammer.
snowball (02-22-2021)
Glyn M Ruck (09-26-2020)
The following 3 users liked this post by cdg66mk2:
