doors
Thanks for the reply. Ive tried that but given how short the bolts are and how much movement away the slide adjustments move I cant even get a bolt started. and a few of the bolts seem impossible to even get to. All this while not damageing any metal or paint. tips or tricks? Thank you kindly. Good day.
gatekeeper (04-01-2015)
Clean original bolts first with a brass wire wheel and if the threads are damaged, refurbish them with a chaser nut. In some cases a tap may be necessary to restore the threads in the pillar.
The use of WD-40 on the threads is always a good idea, work the threads until you can screw the bolts in and out with your free hands.
WD-40 should be used first before using a chaser nut and tap.
To mount the door, use longer bolts to take the weight of the door, leaving one open for one of the original bolts.
With the longer bolts temporarily taking the weight of the door, it will be much easier, to start the stock bolts, removing the longer ones as necessary.
99xk8guy
06-05-2023 06:28 AM
al_roethlisberger
09-21-2015 08:07 PM
RaceDiagnostics
09-13-2015 02:22 AM
