Front Shock Top Spacer
I'm ordering parts for the rebuild of my 420 front subframe suspension brakes and subframe.
There's a spacer/split ring that I removed from the top front shock mounting hole in the subframe turret to accommodate the M16 rod that I used to remove the springs. I think it's item 38 in the sketch in the attached PDF
I can't find this spacer listed separately anywhere on SNG or MR sites.
Does anybody know if it comes with a new shock? If not is it available anywhere?
I'm pretty sure that the new shocks (GAZ adjustable, in my case) came with new bushings and any spacers that you may need. I also removed mine to get the spring compressing rod down through the tower and I have at least one of them somewhere. I like to think that I didn't leave out a necessary part and it was clear that the new setup was all that was needed.
jaguar38s (11-03-2021)
Kuddlesworth
11-05-2021 02:23 AM
apexjag
09-24-2019 12:52 AM
