fuel cap gas cap
Received 1,434 Likes
Example of unvented. Not mine. The original C23601 caps were not as well finished as the repros. Cast in a Mazak type high zinc content material that discolours easily after polishing & has surface inclusions. Don't try & clean up with acidic aluminium brightners. They will fizz away thanks to Zinc content & make inclusions worse. They only respond positively to mechanical polishing. I have 3 cars. My primary resto & 2 donors. All had/have the same caps.
Skimmed over my copy of J12 and cannot see where "fully interchangeable" is stated against any part number , there are many parts where this applies, but I cannot see reference to this in the list.
#28
Absolutely, everything shows this to be the case Glyn, apart from the J12's we haven't seen, and the comments of Coventry Foundation, all posted literature proves the point.
#31
See your own post below
then my reply
It was you that said the J12 normally states this, I know it was on the Bulletin. My point was that there appears to me, not a single part No. on my J12 that has any comment on any interchangeability, so your comment re "The J12 normally states this" did not appear correct.
jimlombardi
05-09-2019 08:17 AM
englevakten
07-14-2018 02:28 PM
1964Daimler
09-08-2015 11:54 PM
chriscowan
01-01-2010 10:32 AM
