Fuel Sender Unit Resistance Min-Max Values
I'm going to try and repair my fuel tank sender unit. Currently it's open circuit, so I probably need to replace the resistive windings and/or wiper, although this is speculation at present as I've not dismantled it yet. In order for me to source the correct wire, does anyone know the minimum and maximum resistance values for the unit please. If anyone has ever done this, please let us know how it went (good or bad!). Cheers.
Received 1,488 Likes
Voucher Boy (04-03-2022)
The following 2 users liked this post by paddyx350:
Glyn M Ruck (04-03-2022),
25 to 250 ohms is the nominal values. I've never tried to repair on at the windings, but look at the terminals, you might be able to repair a break there. These resistance values carry on until at least Series III XJ, so you might be able to adapt another sender. I'll have to check, but I'm pretty sure the range changed on the later XJ40/X300 saloons. Those have plastic bodies instead of metal, so would be more difficult to work with.
25 to 250 ohms is the nominal values. I've never tried to repair on at the windings, but look at the terminals, you might be able to repair a break there. These resistance values carry on until at least Series III XJ, so you might be able to adapt another sender. I'll have to check, but I'm pretty sure th7e range changed on the later XJ40/X300 saloons. Those have plastic bodies instead of metal, so would be more difficult to work with.
VB, I think when you get in there, you will find it's the wiper that has worn, and/or the moveable contact that attaches to the wiper has failed.
There are different arrangements sometime there is a braded wire that moves, or it may have a simple contact on the bearing.
The bearing has become oxidized or it self is so worn that the slider has lost contact with the windings.
If the winding have become broken, they would be all frayed and making intermittent contact when checked with an ohm meter _ you would have readings all over the place when the slider was moved.
Look for a bad connection to the spade terminals through it's mounting plate as well.
The following 2 users liked this post by JeffR1:
S-Type Owner (04-04-2022),
Voucher Boy (04-04-2022)
