Gas Pedal Angle
I just completed this job last week. The first attempt was very wrong. The pedal was way down with the throttle plates closed. I loosened the clamp on the rod and bumped a screw driver in there to hold it open. From the inside of the car, I pulled the pedal back up to where it looked like it should be at idle. There is a mechanical stop that prevents the pedal from going completely vertical and I was close to that position.
Making sure (again) that the throttle plates were closed, I pulled the screw driver out of the clamp and tightened the clamp bolt.
I don't have a seat in my car so I can't tell if the pedal position feel "normal" or not but it looks to be about right.
Hope this helps.
Craig
Hope this helps.
Craig
Received 1,476 Likes
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
