gearbox inhibitor switch
Which gearbox are you running?
The inhibitor switch for the Borg Warner 35 Auto is on the side of the gearbox. I can only relate to the S Type but there is an access panel in the side of the tunnel. The BW35 was not fitted to Jaguars until 1967 but cannot state when Daimler were given this Auto box. According to Wiki,
and the BW35 was available from 1965 on. I have attached a photo of where the inhibitor switch is on the BW35 which can be seen through the access panel on the S Type Jaguar. The access panel is just an over sized piece of metal which is screwed to the side of the tunnel with self tapping screws and is hidden under the carpet. Easy to make if you do not have one.
If you have the DG 250 Auto box I think I am right in saying the inhibitor switch on the Jaguar is under the dash with the gear change mechanism.
In April 1964 the Borg-Warner Type 35 automatic transmission was replaced by a D1/D2 type, also by Borg-Warner.
Received 1,488 Likes
