General MK2 (Stupid!!) Questions
Old 12-07-2013 | 06:39 PM
Jose's Avatar
My, looking at these little bits brings back some memories for me !
of course the glovebox lamp is totally useless lighting the inside of the glovebox, but it sure is a pretty blue light when it comes on in the dark!
sometimes I just stare at mine like a total idiot!
Old 12-08-2013 | 04:23 AM
barrymk2's Avatar
Hi, does anybody know if the switch is still available in uk?
Barry
Old 12-08-2013 | 06:21 AM
Jose's Avatar
Barry
I checked with SNG Barrat UK and it shows NO LONGER AVAILABLE in their online catalog. Part No. C18118
same for the Glovebox lamp assembly Part No. C16008
what they do have available is the Map Lamp assy. Part No. C15486
The glovebox door switch is of the same principle as a door switch for the interior lights, but in miniature.
Attached Thumbnails General MK2 (Stupid!!) Questions-glovebox-light-switch.jpg
The following 2 users liked this post by Jose:
barrymk2 (12-09-2013), SNG Barratt USA (12-10-2013)
Old 01-13-2014 | 01:45 PM
Jose's Avatar
I made a discovery yesterday, I'm going to share it here, please send any $$ donations to me
The Discovery:
First: I own a 1965 3.8 'S' and also a 1984 XJ-6 (Series 3).
yesterday I was warming up the XJ-6 and started testing all the lights, windows, everything electrical, everything worked except the glovebox lamp.
(NOTE: in the S type and the XJ, the glovebox lamp comes on ONLY when the headlights switch is in any of its 'ON' positions, so keep that in mind).
So I started fiddling with the spring-switch, sprayed a squirt of WD40, got it working again and all of a sudden it dawned on me:
it's the same LAMP as in the S type and almost identical switch! Actually it's even better because the lamp housing in the XJ is chromed, but the LENS is WHITE as opposed to the BLUE LENS in the S type and MK-2. Otherwise identical parts except for housing finish and lens color.
I'm now thinking the lamp is the same in the 420, and the XJ-Series 1 and 2 as well, not to mention other Jaguar models.
so...for those looking for a glovebox lamp and switch for their MK-2 or S type which they can't find, go to a Series 3 XJ-6 or 12 and you can "extract" the glovebox lamp and switch from it.
Here's a picture of the XJ-6 glovebox lamp and switch. Fresh from yesterday!
barrymk2 (06-23-2016)
Old 05-20-2014 | 03:52 AM
Tubbs's Avatar
Default Question of my own
I wasn't sure where to ask this. I hope this is ok. I have a 1957 Mark II. Will seats from a 1967 Mark II fit in them?
Old 05-23-2016 | 11:33 AM
nhbonnie's Avatar
Default An Excellent Reference
Eric Kriss recently hosted a tech session for the Jaguar Association of New England. His nuts & bolt restoration, upgrading & modernizing of a 1961 Mk2 is extensively documented & cross-referenced on his blog: Jaguar Mk2 Restoration - Kriss Motors progress blog. I find it a valuable reference regarding my recently acquired 1967 Mk2/340.
Cheers & good luck,
Old 05-23-2016 | 03:57 PM
Fraser Mitchell's Avatar
If your car is 1957, it ain't a Mark 2, but the earlier Mark 1. Actually it was never called a Mark 1 by Jaguar, but the Jaguar 2.4 and 3.4. The Mark 2 from 1959 onwards was a clever update of the Mark 1, so the seats should fit, but check the mountings.
  #28
Old 05-24-2016 | 01:31 PM
rtipping's Avatar
Default Kriss Motors
Cheers & good luck,
I have subscribed to this blog for a couple of years now....its invaluable!!!
Old 06-21-2016 | 05:27 PM
TilleyJon's Avatar
Hi,
looks like you have the answers, just one point re dipstick, the 2.4 and 3.4/3.8 have different part numbers for the dipsticks, although the bottom end is the same the dipsticks must vary, there a a total of 4 different part numbers for different engine numbers on the 2.4 or dipstick arrangement (i.e. guide tube) on 3.4/3.8.
In theory they should be the same length into the sump, but better not to assume when it comes to oil levels, I had an engine blow up on me after I bought a vehicle where someone had cut 3 inches off the dipstick tube, so a full sump was actually empty !
Forcedair1
02-19-2020 02:51 PM
Goncalo Proenca
09-28-2015 02:26 PM
1964Daimler
09-09-2015 12:28 PM
deanh
09-06-2015 09:20 PM
lordpeterk
09-06-2015 02:50 PM
Quick Reply: General MK2 (Stupid!!) Questions
