The Good, the Bad and the Ugly
Old 12-17-2017, 03:03 PM
jagstuart's Avatar
Default The Good, the Bad and the Ugly
good nice paper trail
good $1800 in carpet, felt rubber and full interior kit
bad passenger side tank open to elements
ugly PO's pile of unmarked hardware, etc. found under the good stuff. Bowls and baggies! Really!?
Let the fun begin! Got it home and in the garage just before the first winter rain. Thanks to my son's help we pulled and pushed it up hill into the garage. Charlie! YOU DA MAN!
Old 12-18-2017, 02:39 PM
csbush's Avatar
Looks like a good project. I look forward to hearing about your progress!
Old 12-18-2017, 04:55 PM
Jose's Avatar
Received 2,450 Likes on 1,845 Posts
don't throw anything away. You will need it.
the gas tank cap you can order from SNG Barrat USA store. Also order two rubber seals for the tank drain bolts at the bottom.
you can clean it in place with a garden hose and good water pressure after you remove the drain bolt, and the Sender assembly. Then replace every thing, and fill with 87 octane. Add a bottle of STP conditioner.
Old 12-19-2017, 12:37 AM
TilleyJon's Avatar
Great stuff, I got a similar pile of bits in the 2 cars I have, but 2 years later, I can probably identify almost every bolt.
These restorations do give you a very close understanding of the cars, and where would the fun be if it were all labeled !!!
Stuart S
12-26-2014 03:40 PM
jagyankee
11-27-2013 05:44 PM
Lothar52
09-27-2013 07:05 PM
bdelgros
07-08-2010 08:52 AM
Quick Reply: The Good, the Bad and the Ugly
