Got the head off.
#61
The problem Brent has is the car is stuck on a steep driveway, so it's a safety issue rather than practicality unfortunately.
Oxidation on Aluminium does protect it as long as the enviroment stays fairly Ph Neutral. Oxidation does still continue, but the rate slows up dramatically after the first layer occurs.
The covers you sent had obviously been left for quite a considerable time as the layer was pretty thick and hard, but a few hours of elbow grease does wonders.
#62
#64
Received 1,442 Likes
The core plugs or Welsh Plugs in your pic certainly look the real deal. You may be more familiar with the "skirted" style of plug on other engines, but Jaguar XKs used ones in the form of a domed disc . . . giving rise to a number of observations . . .
Time for the dreaded Murphy to make an appearance . . . if you replace all the other plugs with bright shiny new ones, guess which will start leaking exactly 29 days after you have buttoned up your shiny new engine? Oh . . . and ask me how I know.
Cheers,
Ken
- sealing is confined to edge lip only so a close fit is essential, aided by use of suitable sealant;
- fit with domed face out, then use hammer and solid drift only slightly smaller diameter to flatten dome, thus expanding plug diameter to seal;
- IIRC, number of plugs supplied seems right . . . beware ending with one left over!
Cheers,
Ken
wearlej (04-04-2018)
#65
My attempt to replace the rear frost plug under the inlet manifold, only discovered when I capitulated and removed the block to replace the rings, this lead to the bearings being replaced and the oil pump checked out, radial clearance is close to max on the pump I had in the spares box. The incumbent had ingested, (I am guessing) the tails of the split pins from the big ends. I tuned up the end clearance of the pump and it should be good for another 100K miles.
With the split pins I open the ends sufficiently wide so they cannot back out and then trim off until there is about 8mm protruding. With the retaining springs in the cam sprockets, once everything is locked up remove and hang on a nail in the garage. They can’t do any damage to the engine up there!
#66
The recess the Welch washer sits in should be clean and free from defects, so be careful when cleaning the recess to avoid scratches or gouges.
The plug should not be flattened completely, it should be flattened more than 30% of it's dome height but not completely.
If they are flattened completely they can leak, and you have to start again.
#67
So they're different on the Jag.. Of course they are. What a surprise.... *sigh*
I am just going outside. I may be some time.
Yes, had this happen on a HD Premier once...
#69
Well, waved the car off today! I thought it was a bit unfair to expect Jon to come all the way up here to grab it so over the weekend I looked up transporters and got a reasonable quote. What I didn't expect was for the transporter guy to turn up almost instantly!
So it is on its way, and looking at the online tracking... It's in Bath already! So it is not too far away!
Online tracking you ask? Well oops, I'd left a phone in the thing !!!!
Just need to organise a time to get down there now and work on it, it's quite an odd feeling looking outside and not seeing it
#72
#73
#74
I replaced core plugs on a 2.4 litre and also a long-stud 4.2 litre XK engine and the later block uses the later type of core plug and has no lip for the plug to seat on, unlike the earlier dished washer type. Both sealed OK. I used a bit of red Hermatite on the 2.4 plugs, then washed the surplus off the outside with cellulose thinners. For the later engines, I think I used a smear of Hylomar, but its a long time ago now, so memory fades.
wearlej (04-11-2018)
#75
Thought I had better do an update, had a good look over the car, and a couple of issues came to light, timing sprockets are all worn and will be replaced, sump gasket, high capacity oil pump, timing chains all ordered, some were not in stock, so had to await back order.
Parts arrived last week but top sprockets still out of stock, but need to get the job going so into the workshop to drop the front suspension.
Found a couple of further issues, the drivers side Vee mount had let go and the front sandwich mount was also separated, so only the passenger side mounts, the anti roll bar and the steering column were holding the front suspension to the car !
Then found a nice increasing patch of oil on the floor, as the car is now up on an angle the rear crank seal is showing it's normal leaking !
So out with the engine next, will pop the crank out to replace or upgrade the oil seal and hopefully there are no surprises when I get the crank off.
Brent has a bunch of new parts that he had already got prior to the car coming to me, so the suspension will have a new set of bushes, new engine mounts as these were toast, core plugs, upgraded radiator, new hoses, crank seal, suspension mounts, and also the lower steering column bush as has been smashed by the bouncing front suspension, new timing gear, crank damper and a refurbished head.
Not sure if I have forgotten anything, and will update as work progresses.
Brent is coming up for the day to lend a hand and get oily on Friday, hopefully will get most of the work done by then so he can help putting stuff back together.
wearlej (05-15-2018)
#77
#79
