Ground Near Coil - What Type of Screw? Brass or Galvanized or????
There's a loose ground wire near the coil. I've tired to screw it back onto the fire wall (Yes, I scrapped the firewall and cleaned the area with spray).
But it won't stay. So I must not have the right sized screw. What size is acceptable, and what type of metal? Brass? Zinc? Galvanized?
And should I use a washer between the screw and the ground?
( I mustbe making progress. Neighbors are coming out to look at the car, and I smell of gas and grease even after washing up.... )
It almost looks like a brass wood screw _ the photos are a bit out of focus and the threads can't be seen clearly.
At any rate the upper part of the shank doesn't look threaded so I would think by the time the under side of the head makes contact with the ground leads, all of the thread will be on the other side of the firewall.
If you try and tighten it, it will just go around in circles.
