Heres my leak
Received 1,463 Likes
See here.
https://www.jaguarforums.com/forum/m...cation-209831/
That is the cam feed Y pipe.
You likely only need new copper washers on all banjo joints.
Part number for copper washers. C4146
Part number for cam feed pipe if needed. C25619
chris tian (01-18-2019)
Correct Jose as I said above. Christian. Each of the 3 terminations of the Y pipe has a banjo fitting. 6 copper washers required to seal them all. 2 per banjo joint. These banjo joints are not separate they are part of the cam oil feed pipe. Check the pipe for cracks if the new copper washers do not fix the leak.
chris tian (01-19-2019)
The following 2 users liked this post by S-Type Owner:
chris tian (01-19-2019),
Glyn M Ruck (01-19-2019)
Get the correct washers with squash rings as per picture in Jose's posts and the other thread Glyn linked to.
Oh and just for interest Chris tian the washers are copper, the Banjo in your picture is brass, some of the new ones are plated, but I actually don't know what they are made of, in my opinion the Brass ones seal better than the plated ones, it may just be coincidence but that's my experience.
The following 2 users liked this post by Glyn M Ruck:
TilleyJon (01-19-2019)
TheBrightKnight
07-23-2012 09:14 PM
jagxkrtoofast
02-24-2012 07:45 PM
etaent
02-18-2012 05:08 AM
andy303
11-14-2011 06:39 PM
