Hood Trim Clips
Old 06-12-2023, 05:21 PM
jerry_hoback's Avatar
Received 1,150 Likes on 807 Posts
Here is a pic of my 65 built S-type. It appears to be a probably a "twist in the trim" thing, then with the tabs bent over. I have no idea of a part number, just throwing it out there as a "likely original assembly part."Hood Trim Clips-photo161.jpg
  #42
Old 06-13-2023, 02:21 AM
Glyn M Ruck's Avatar
Received 1,452 Likes on 1,124 Posts
Originally Posted by jjholloway
Good evening,
Do you have the the part number of the trim rivets you used for the front centre bonnet & front of front doors?
Or any idea of where I can find them online?
(I did buy a pack of the clips .... they do seem awful so i'm keen to avoid using them)
Many thanks
These work a treat on all side strips.
Require a thin shank pop riveter to fit inside the dome & pull tight before breaking the tang.
  #43
Old 06-13-2023, 04:02 AM
Sorry ~ did you mean these? I used these for front of bonnet & doors. They do a very good job. If you don't fit the strips will blow off at speed. They should be in the Barratts kit. You don't see them once chrome is fitted.
This is the kit.
P/N ~ Barratt's SBS1271FK ~ apply no Model filters & they will pop up on the Barratts UK website.
  #44
Old 06-13-2023, 05:35 AM
This is your alternative but will take a monster Ebay search to find and they come & go.
Can be used for entire centre bonnet moulding and front of front doors. Some are better made than others.
JeffR1 (06-13-2023)
  #45
Old 06-13-2023, 12:08 PM
JeffR1's Avatar
That would be a neat lathe project; get some standard bolts in stainless steel and make some.
Glyn M Ruck (06-13-2023)
  #46
Old 06-13-2023, 01:03 PM
Yes Jeff. You could certainly make your own in SS. I fail to see the problem with the originals in the kit however, but to each his own.
  #47
Old 06-13-2023, 05:10 PM
JeffR1's Avatar
I just have a thing with things that will eventually rust, even if it would take a long time.
Just me being OCD.
And welcome back.
  #48
Old 06-13-2023, 11:29 PM
Thanks ~ don't worry ~ I'm just as OCD.
  #49
Old 06-14-2023, 04:31 AM
Peter3442's Avatar
Received 1,318 Likes on 989 Posts
The advantage of stainless fasteners is very clear to me as I've been removing the trim and lights from the front of my car. The Mk2 teardrops over the headlamps seemed difficult at first, but a good twist works well. A couple of headlamp screws were awkward. Unfortunately, there's no access for using an angle grinder on the Fograngers. I've not figured how to remove the rusted clips on the little red telltales - looks like angle grinder work.
In spite of all that, those stainless nuts and bolts a few posts up look a bit heavy duty for attaching a strip of chrome. It's holding a chrome strip, not mooring the Queen Mary!
Glyn M Ruck (06-14-2023)
  #50
Old 06-14-2023, 05:46 AM
jjholloway's Avatar
Thanks for this! I managed to find some on ebay, hopefully i'll get this done in the next couple of days
  #51
Old 06-14-2023, 09:06 AM
Just remember that ideally you need to slide each one into your chrome strip. They are not really designed to be an easy press on clip like the riveted variety that I show on the Maroon Mk2.
jjholloway (06-21-2023)
  #52
Old 06-15-2023, 12:32 AM
Bill Mac's Avatar
Received 1,048 Likes on 611 Posts
I made similar bolt on clips from pan headed screws by filing the sides of the pan head to fit into the chrome mouldings.
These are on my current MK1 bonnet and I have done this on a number of other restorations.
My MK2 bonnet centre moulding is still using the original twist into the slot and spring the moulding over the clip system.
The pop rivet system does work ok on the body side mouldings, but I still prefer to use the original bend over tab system on the bonnet side mouldings.
Glyn M Ruck (06-15-2023)
  #53
Old 06-15-2023, 03:48 AM
Absolutely Bill. That's what I used & they are in the kit.
Poor pic but you can see the bent over tabs on the bonnet sides.
Excuse reflections & rubbing compound.
The following 2 users liked this post by Glyn M Ruck:
Bill Mac (06-18-2023), JeffR1 (06-15-2023)
kkurulak
11-26-2017 07:17 PM
rfoulds
06-18-2017 01:42 AM
Jon89
30
01-13-2016 06:20 PM
Ed C
02-19-2015 10:16 AM
imagineaudio
06-06-2013 01:23 PM
Quick Reply: Hood Trim Clips
