how to fit: zf 4speed 4hp22 auto on mk2 3.8?
HP22
Hi, it could be done by using an adapter plate, alloy or steel.
Problem is to center the thing otherwise judder ,
best remove the engine, than buy a good second hand auto box HP22.
Use the old Borg warner to make the adapter plate.
I made one for my Austin Healey, MK2 , BT7.
Reason for that is my handicap !
Good luck, Han.
Good luck, Han.
The ZF box doesn't have a mechanical speedo take off. People I know who have done the conversion on V8 Rovers use the Dakota digital electronic drive.
Dakota Digital's ECD-100 Electronic Speedometer Cable Drive Unit - YouTube
The trouble is the cost.
Peter
Peter
Hi again folks including Stoney 85.
I am in Victoria,you can get me on 0419 322 899.Iam not good at keeping photographic records,and although the assembly is now fitted and ready for start up a problem arose today,with fluid leaking from the transmission between the Volvo ext,n housing and g,box housing due to the head of a bolt fouling the inside of the ext,n housing.All fixed now,but it is suprising how many small differences there are in areas where you would think there would be interchangeability.
I have fitted a VDO electronic speedo but until the car is road going and the necessary setup procedure is complete I will not know how successful this will be.
Cheers for now.
Cheers for now.
Hey guys as there are a lot of Auto guys on here can anyone help with this thread ?
https://www.jaguarforums.com/forum/m...lector-174171/
#30
#31
Maurie
I am placed in Melbourne . Cheers Maurie.
Glyn M Ruck (07-07-2024)
#32
Received 1,048 Likes
If all else fails in trying to get a speedometer working, I suggest go for a GPS speedometer.
I have been using them for years in addition to normal speedos.
They are far more accurate than any mechanical or electric system fitted to the majority of cars.
The only problem is they don't work in tunnels.
The following 2 users liked this post by Bill Mac:
Glyn M Ruck (07-09-2024),
Peter3442 (07-09-2024)
