Initial Startup
Received 1,481 Likes
Yes. Pull the HT lead on the coil & just crank until you observe oil pressure on the gauge and remove the oil filler cap & observe oil flow to the cams.
Then you are safe to fire her up.
See:
https://www.jaguarforums.com/forum/m...cation-209831/
See:
Glyn M Ruck (08-30-2022)
Good call Rob. I almost read your mind on that one. Much hissing going on via the plug holes. While I did not do that it is a fine idea.
I had it in the back of my mind. Cass would remove the plugs ~ sensible chap.
At the same time make sure that all is clean around the plug holes so nothing can drop into/be sucked into the engine like that small nut that you don't know where goes.
The following 2 users liked this post by Peter3442:
Bill Mac (08-31-2022),
bullittandy
03-03-2022 12:46 PM
