Jaguar Mk 2 problems selecting 1st and reverse.
Hello all I have a friend that has just bough a 1968 Jaguar MK2 2.4 Manual. It's got a problem with the gate on the gear selector when you try and select first it goes into reverse sometimes. Can this be fixed with and new selector/linkage? if available , I have fixed some other cars such as (Mazda Mx5) when the bushes are worn out in the selector unit. Or is this a gearbox out and internal repair job?
Regards
Galee
Regards
Galee
It's a long time since I had a Mark 2, but as I remember, you have to force the lever past a detent spring before you can push it into Reverse. It could be the spring has got weak over the years of working the gears. If this is so it may just be a matter of taking off the top of the gearbox.
A 1968 Mark 2 2.4 is a year on from the car I once had, and same engine too. It therefore should have the all-synchro box like I had. I can't remember where reverse was, but if it's going into reverse instead of first gear when about to drive away, then it sounds like the detent to prevent accidental reverse selection isn't strong enough. On the box on my MG Midget one has to pull-up the lever before you can select reverse. I think the Jaguar all-synchro box didn't have anything like this.
Regards
Galee
Regards
Galee
Received 1,434 Likes
Glyn M Ruck (09-16-2019)
Sorry I have not got the hang of this forum. Apologies for any spurious attachments.
I have now got the console and cover off. I am guessing the reverse gear detent operates directly on the fork. My question is: if I undo the bolts on the lower flange, will that release the selector assembly and will it come out of the hole in the tunnel? Also can an any bits fall off and will I be able to reassemble it?
Pete
Pete
mike213735
10-02-2013 12:57 AM
