Jaguar MK2 2.4 Restoration Project
Old 02-24-2019, 09:28 AM
blot3.8's Avatar
The problem with the Practical classics 340 was that the guy who did the body restoration was reletively inexperienced in this type of involved structural repairs and the resulting problems with a distorted shell underlines this, You on the other hand have a wealth of experience and know your onions and your photo's show this. I think you are doing an epic job and saving yet another MK2 that would of been scrapped or banger raced and i look forward to more progress.
  #62
Old 02-24-2019, 01:29 PM
Robman25's Avatar
Just a tip when posting photos, insert a line space between each download, this will seperate the photos just as they are when you place text to describe the photo.
Great job BTW.
  #63
Old 02-24-2019, 01:34 PM
TilleyJon's Avatar
Bloody hell Homer, good job big thumbs up from me mate
  #64
Old 02-24-2019, 02:58 PM
Homersimpson's Avatar
Great job BTW.
Thanks i've gone back and done that, i was so pleased that the uploading worked (I usually have trouble with it) thatI didn't notice the lack of a gap!
  #65
Old 03-16-2019, 04:27 PM
Hi, can anyone tell me the measurement from the inner sill to the accelerator pedal captive bolts? I need to replace these and the 1959 car doesn't have them to measure.
  #66
Old 03-17-2019, 01:30 AM
TilleyJon's Avatar
I assume you have the Organ type pedal with the four bolts on the floor pan ?
I can get the measurements either later or tomorrow if no one else can help sooner.
  #67
Old 03-18-2019, 09:48 PM
csbush's Avatar
I have a 67 MK 2. The distance from the front of the inner sill to the bolts on the back side of the pedal mount is 25.25 inches. Insulation and soundproofing removed from the seat sill.
I haven't dug through all the rust and dirt yet to know exactly, but it looks like my floor mounted accelerator pedal is held on with two bolts on the back side. They both are the same distance.
Let me know if you need anything else.
Chuck
  #68
Old 03-19-2019, 04:33 PM
Chuck
Thanks Chuck,
I put the throttle linkage back in in the end and used that to mark the pedal position and then welded the nuts in from below.
  #69
Old 07-24-2019, 02:26 PM
I've been working away in the garage and haven't had time for an update so here it is!
N/S inner wing repair
N/S inner wing lower repair finished
Inner Sill Replacement
Front floor pan replacement
Old removed chassis rail full of rust
New chassis rail fabrication
New chassis rail ready to fit
Old chassis rail removed and metal cleaned up
Old spring hanger box removed and metal cleaned up
New chassis and spring hanger box installed, car on rotisserie and alignment checked.
Completed alignment check, all looking good so far
The following 2 users liked this post by Homersimpson:
littlelic69 (07-30-2019), S-Type Owner (07-27-2019)
  #70
Old 07-24-2019, 02:51 PM
Orlando St.R's Avatar
That's amazing work! You really have brought that car back from the dead. Congratulations.
  #71
Old 07-24-2019, 03:06 PM
Thanks, there is still a very long way to go though!
  #72
Old 07-25-2019, 10:53 AM
Bob_S's Avatar
Homer, Nice job!!! I wish I could do that!
  #73
Old 07-27-2019, 12:37 AM
TilleyJon's Avatar
Nice job Homer, keep up the good work.
  #74
Old 07-31-2019, 02:07 PM
blot3.8's Avatar
Skillz Love it! (I can see why you haven't got the time to do those 'few' jobs on my MK2 now Homer!)
  #75
Old 08-01-2019, 01:34 PM
gene61jag's Avatar
That's awesome man. You're doing God's work.
I replaced my petrol tank while restoring my Mk2. It has a couple of pinholes but with your welding skills...
PM me your address and I'll see If I can ship it to you, if you like. The Wife would love to have the space back and I would appreciate knowing it is serving a good purpose.
  #76
Old 08-04-2019, 05:01 AM
Thanks Gene for the kind offer, i'm in the UK so I suspect shipping costs would be significant and i'm not overly keen on welding up petrol tanks (only did it once and got away with it but not keen to repeat :-)
  #77
Old 08-04-2019, 05:02 AM
Thanks blot, I also now have a 4 week old son (as well as a 4 year old daughter) so time (and money) is tight :-)
blot3.8 (08-04-2019)
  #78
Old 08-04-2019, 09:24 AM
blot3.8's Avatar
Homer, You deserve a medal mate I'm tackling my MK2 myself, Whilst i haven't got your welding and fabrication skills i consider myself just about capable of doing the few bit's my MK2 needs, I had a look around it yesterday and it's actually not as bad as i thought!! Cheers.
  #79
Old 08-05-2019, 01:41 PM
gene61jag's Avatar
I would have to investigate shipping before I got scared of it. And I understand your trepidations of welding a petrol tank. The last fluids the tank had in it was anti-rust chemicals, not gasoline.
But I will respect your wishes. Last I checked gas tanks were not terribly expensive. May you have continued success with your restore
  #80
Old 08-09-2019, 04:49 PM
I've been scraping the underseal off the bottom of the car today and there was a large patch of filler under the offside wing, a bit of a gentle tap and a small hole appeared. It seems that someone in the past has cut out a slot of metal from top to bottom on the front wing and then roughly tacked a patch behind it (which fell off) and then troweled it full of filler.
If I kept tapping I would have a slot all the way through. Thats going to take some fixing!
Quick Reply: Jaguar MK2 2.4 Restoration Project
