Jaguar MK2 2.4 Restoration Project
Old 09-28-2019, 01:57 PM
Homersimpson's Avatar
t
Some photos of the side light hole and also the piston and crank after removal.
blot3.8 (10-13-2019)
  #102
Old 09-28-2019, 01:59 PM
Originally Posted by JeffR1
What about custom pistons ?
I had some made for my Bentley when I did the engine, they were better and a lot less money, I payed 600 us dollars at the time for 6 pistons.
They had a very short skirt and forged out of round, so when they heat up, they become round, better alloy too then the originals.
Hi Jeff, I can get new piston, they are just expensive. they would however almost certainly be cheaper than having them made.
  #103
Old 09-28-2019, 03:32 PM
JeffR1's Avatar
Yes, you're right, a set from XK's is around 500 US dollars, not that this matters but Introcar wants £145 for one Bentley piston, so in that case, custom is less expensive.
  #104
Old 09-30-2019, 03:54 PM
Fraser Mitchell's Avatar
Received 2,455 Likes on 1,951 Posts
I must be honest I did really want to do it as a 2.4 as i've never owned or driven one of the smaller engined ones and my economy/budget aim fits in with that. I will have to see what comes along at the right price, one problem seems to be that 2.4 pistons are not as easy to get hold of, David Manners do 3.4 and 3.8 one for around £200 per set but don't do them for the 2.4 and people like SNG Barratt are a lot more expensive.
The bore size on the 2.4 and 3.4 seems to be the same and I did wonder about using 3.4 pistons but there must be a reason why they were different originally, does anyone know what the difference is, is it crown to gudeon pin distance?
Whilst the bore size is the same, the block is a whole lot shorter, being nearly 2" shorter. This means shorter conrods and they will be at much more of an angle to the vertical at half stroke, so I suppose this affects things to a degree that demands different pistons. BTW, I had a 2.4 and whilst you're not going to "dump rubber" with it, it is a lovely smooth engine that can be revved. Jaguar never released 2.4 litre cars for magazine testers because the 2.4s wouldn't get to 100 mph. It took the 240 with SU carbs and a different cylinder head to do that, even so it could only make about 105. However, for cruising around the 2.4 is adequate.
  #105
Old 10-12-2019, 03:35 PM
So I've been doing a bit more welding and have repaired the base of the A pillar.
Ive had to buy my second 8x4 sheet of steel!
  #106
Old 10-13-2019, 09:21 AM
blot3.8's Avatar
Hi Homer, Love this project of your's, Only reason i come on here now is to check out your Skillz! As for the engine mate i would ditch it! A 2.4 after driving your 3.8 would be a bit of a disappointment, I just bought another S3 4.2 injection big valve with all ancilliarys including the auto box (Which i don't need) for £900 shipped, Got it from Keith Parrington at XJ Restorations, I'm putting it in my S1 XJ6 as well as a manual box and a recently acquired 3.54 Powerlock diff,
  #107
Old 10-13-2019, 02:25 PM
Hi, thanks for the kind words, with regard to the 2.4, I've always found the smaller engined versions of cars nicer to drive, the 850 mini, the 948 Sprite etc, as engines seem to get bigger they seem to get harsher and I've always wanted to see what the 2.4 is like. It will all depend on what comes up at the right price.
My days of driving like I stole it are well behind me and I don't really use the power of the 3.8.
  #108
Old 10-13-2019, 02:29 PM
This evening I've finished welding the repair into the o/s wing and screwed the when arch in.
I've done a bit of panel beating and with a skim of filler I think it will be good so no new wing required 😊
  #109
Old 10-18-2019, 06:07 AM
blot3.8's Avatar
Fair enough mate! The short block XK motor's are turbine smooth and love to rev, Though they seriously lack in torque so a manual gearbox conversion is a better idea over an auto, If you stick with a 2.4 at least get a straight port head and SU's to give it a chance! Solexs' strangle it a bit, Still expect 3.4/3.8 fuel consumption though!
  #110
Old 10-24-2019, 11:13 AM
littlelic69's Avatar
I have, today received this month's copy of Jaguar Enthusiasts Magazine. In it is a 2.4 litre engine for sale at £150. Quote " For rebuild or spares" Phone 01724 720751. It may help! Alec G.
  #111
Old 10-24-2019, 01:03 PM
Thanks I will give them a ring, if it turns it might worth a punt!
  #112
Old 10-24-2019, 01:05 PM
Yes I had heard that the 2.4's fuel consumption was on a par with the bigger cars, I just fancy the idea of one.
I would like to do a manual converstion but the cost of the bits will probably make this prohibitivly expensive and I don't mind the nice lazy (and in the case slow) auto.
  #113
Old 10-28-2019, 04:30 PM
Tonight I've fitted the offside rear jacking point which was the last one of the four.
I've now started on the rear wheel arch and found (unsurprisingly) more significant rot.
  #114
Old 10-28-2019, 04:35 PM
I also recently repaired around the pedalbox which was.... yes you guessed it, rotten.
  #115
Old 11-24-2019, 03:58 PM
More fabrication and welding
The following 2 users liked this post by Homersimpson:
csbush (12-11-2019), S-Type Owner (11-25-2019)
  #116
Old 11-27-2019, 04:01 PM
lornemalvo's Avatar
Originally Posted by DaimlerMK2
you can make some chassis legs out of 60mm x 60mm box if you wanted,and the front cross member same,
Do you have any more information on this, and /or photos?
  #117
Old 11-30-2019, 08:50 AM
I'm afraid I don't think this is feasible because the chassis rails at the front are a very complicated shape wher the subframe mounts to.
The section under the floor thats straight is easy to replace but its a top hat section and as you can see from mine I have this folded up by a metal fabricator and cost very little.
Which bits of the chassis rails need to be replaced, do you have any pictures?
  #118
Old 11-30-2019, 01:47 PM
lornemalvo's Avatar
At the moment, it's the straight section and I don't see why box section with a plate welded across the top wouldn't work, to be honest. The front, complex part would be assessed when I have the engine out. The straight section has rotted out where the front jacking points meet them. The two options I'm considering are below
  #119
Old 11-30-2019, 04:00 PM
You could do this but if you need to change the bit that fits into the rear spring hanger it would be more difficult and it might look a bit odd underneath.
I had a pair of the top hat straight sections of the chassis rail made to my dimension by a company called GDI products on e-bay, they were around £50 delivered. It was fairly easy to modify these to flare the end by cutting the bottom off, notching the flanges and welding a new section in.
The listing is here:
https://www.ebay.co.uk/itm/MILD-STEE...gAAMXQ3kRQ8-v7
I think I had them made 62x62 with 15mm flanges either side and 1300 long and they were ideal for the straight section.
Best of luck.
  #120
Old 12-01-2019, 05:52 AM
lornemalvo's Avatar
That's brilliant, thank you. Ho thick were the sections they made up?
Quick Reply: Jaguar MK2 2.4 Restoration Project
