Jaguar Mk2 barrel lock replacement
George, what is the problem with having 2 keys instead of one. As it is if someone has a key that may provide entry it will not turn ignition!! Or cant I see the wood for the trees.Is it that you have not got keys for the door locks?
In my car you need more than one key and that I like.
barry
barry
from the factory, the front doors' key is the same for the ignition switch, a second key is for the trunk/boot and glovebox.
Jaguar Replacement Car Keys
Thanks everyone for your time. Problem was that none of the keys I had worked in the locks. Managed to remove the push button mechanism (pulled from inside the door) by removing the two screws at the top of the spring retaining bracket and the clip holding the locking arm to the push button mechanism. No need to remove the handles completely from the car. Hope this helps someone searching the forum.
msdg137
09-16-2015 06:24 AM
Terrance Williams
08-26-2015 11:50 AM
