Leaking from behind dash onto floor
I washed my car today and found water in the footwells on both sides (not much but enough to concern me). I could feel that it had dripped down from behind the dashboard.
The most likely culprit looks to me to be the scuttle vent but does that really make sense? Maybe the windscreen seal? Any idea's?
Received 1,488 Likes
Wiper shaft seals as Jose says. Lower corners of windscreen. Scuttle vent is well drained so only if rust is present or drain pipe is blocked. Quarterlights (No Draught Ventilators) can't take a direct blast from a hose but you would have noticed that.
Scuttle vent drain tube.
S-Type Owner (04-22-2024)
The following 2 users liked this post by Peter3442:
Glyn M Ruck (04-21-2024),
I have had success with this stuff fixing a ripped door seal om my XK8. PERMATEX BLACK SILICONE ADHESIVE SEALANT.
Correct fitting. Excuse resolution. Snipped from a much larger Photo.
Glyn M Ruck (04-22-2024)
The following 2 users liked this post by Fraser Mitchell:
Glyn M Ruck (04-23-2024),
Peter3442 (04-23-2024)
