Mark 1 engine is racing
As I started my 1959 3.4 litre Mark 1 today the engine started racing at about 2,000 rpm. I drove it around a bit and the idling revs went up to 3,000 rpm when I came off the gas pedal. I adjusted the idle down to 1,000 rpm with the idling screws on the carburetors but as soon as I pushed the gas pedal the engine started racing again. Is this a problem with the gas pedal linkage or is it in the carburetors? Any advice would be most welcome.
Received 1,481 Likes
S-Type Owner (12-02-2022)
Glyn M Ruck (12-02-2022)
Thanks Glyn and Schmitty for your advice. I had neglected to reconnect the throttle return spring when I removed the air intake to change the spark plugs. Once reconnected, it runs very nicely. By the way, I found a complete 282 page shop manual for the car online at: https://jaguarrules.ru/wp-content/up...hop-Manual.pdf
The following 2 users liked this post by jrosenfeld:
Glyn M Ruck (12-02-2022),
Schmitty (12-03-2022)
Glyn M Ruck (12-03-2022)
3.4 only ~ remember there are 2 throttle return springs with SU carbs. 75 & 76. ~ 2.4 had Solex carbs until 240 arrived.
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/425x206/carbs1_f1e00828f94f2d40a87c604e7ac4d8cb04fae38c.jpg)
Thank you Schmitty
l3uddha
08-11-2014 09:19 PM
MLRocafella85
06-22-2011 11:20 AM
