MII central locking / imobiliser
best solution in my opinion
Ravelco Anti Theft Device
I have used this at work and personal and they do stop any hot wiring. Then I would recommend an alarm and an extra hood lock to help deter towing of the car
I have just prototyped an RFID reader which controls 2 relays, these will control the starter solenoid feed from the start button, and also the ignition feed to the coil, took a bit of working out, but after I got my head around it, it was quite easy. I will look at using the fuel pump feed as another defense as this would also need the boot open to be able to bypass the system.
I have to put it into a box, and mount the RFID reader inside the newspaper tray, I am re-wiring the car at the moment, so it is really easy to fit, but it could be simply installed behind the radio console and the connections to the existing wiring are simple enough. If you are interested I will post more information. I actually have an LCD screen attached for testing, but I won't fit that, but I may well add another relay to turn on the Map light for a second just to tell me the card has read and that I can start it.
The whole lot cost less than £20, and it can easily be expanded, I am looking at adding SMS message sending if someone opens the car without the correct fob, and GPS real time tracking too. But this doesn't do central locking, as I want to keep that part stock.
I installed electric locks on my front two doors from a1 electronics, you hide the box under the dash and install the mechanisms inside the doors to pop the lock up and down. It's a little fiddly but works without any problem. I unhooked the rear door mechanisms so the doors will not open from the outside. I couldn't figure out how to fix the locks on the front doors so i just replaced them completely. The car is now pretty secure door wise, it's impossible to pick the lock, you'd have to either break the handle or crowbar the door open to get them unlocked.
As for immobilizers, i can't have a battery kill because then you couldn't open the electric doors. I'm planning to install a 123distributor with bluetooth functionality, that unit connects to an app on your phone and actually kills the distributor unless you enter a 4 digit code. So even if the car was broken into, AND hotwired, the distributor wouldn't work without being unlocked by my phone.
