Mk1 build
Thanks for the warning @Cass3958 but apart from crash damage repairs this has never been welded, obviously it will be welded as front floor pans need repairs
this is a mk1 escort we are currently doing so I know lots about rust 😂
my guy will charge approx £1500 to soda blast and prime and will go on a roll over jig!
anjum (05-28-2020)
Try phoning K Blasting and ask for a quote. There web site is https://www.kblasting.co.uk/
Even if you had the shell transported down it might be cheaper than what you have been quoted up country.
I was lucky or maybe wise to buy the best chassis and shell I could for my S type project but as per your escort I have a Ford Anglia in a similar condition which I am struggling to motivate myself to continue. So much to cut out and weld back in. Chalk and cheese to the S type. At least the panels for the Escort are available and relatively cheap. The Anglia panels are rocking horse and bloody expensive if you can find them. Over £700 for two floor panels..
The following 2 users liked this post by notenoughtime:
anjum (05-28-2020),
Voucher Boy (05-28-2020)
The following 2 users liked this post by domain58:
notenoughtime (05-28-2020),
anjum (05-28-2020),
#30
#32
#33
its a guide coat, you block flat the primer and any imperfections show up as the black will be lower in the primer, you can then get the primer 100% flat
#34
Ah, Thanks for that. I've been Youtubing and now I'm a guide coat (armchair) expert. I've googled it a few times before, but because I didn't know to include 'Guide Coat', the results weren't what I was after. Cheers...
#35
Wow you and Voucher Boy sure power on with the jobs. I am frustrated to have to wait so long to get anything done. The car goes ( I hope ) to the body shop for rust repairs which are beyond my expertise. By then the covid 19 restrictions should be eased and our Men's Shed should be open and I can look into fitting the new aftermarket brake booster.
Please keep the posts and photos comming.
Regards,
David Bruce. Australia.
Regards,
#38
#39
notenoughtime (06-03-2020)
