Mk1 build
Old 06-03-2020, 02:59 AM
Homersimpson's Avatar
If you remove the old wing carefully you might be able to sell it on to someone who is able to repair it.
anjum (09-21-2020)
  #42
Old 06-03-2020, 03:32 PM
notenoughtime's Avatar
im not fitting a whole wing, just the damaged front part
  #43
Old 06-03-2020, 04:30 PM
That sounds like a good plan, i've never tried fitting a whole wing but i've been told by people that have that its not something they would want to repeat. You only have to look at how much lead Jaguar used on them originally around the grille and scuttle to see how much trouble they must have been.
Your really lucky to have a MK1 and a MK2, i've always fancied a MK1 but never found one at a price I could afford.
  #44
Old 06-04-2020, 12:30 AM
If this hadn’t come up at the price it was I’d never have bought one either, one of those to good to turn down
  #45
Old 06-05-2020, 04:04 PM
I’ve welded up the front of the right hand wing today, and started to remove the paint from same wing will add some pics tomorrow
seeing as I want to take it to the Le-Mans Classic next year I’m thinking of making an alloy fuel tank to go above the rear axle then I can do less fuel stops
  #46
Old 06-05-2020, 04:27 PM
I think that the beechams MK2's used an XJ6 tank in this location, you could configure it like the old S-Types with the twin tanks.
  #47
Old 06-06-2020, 02:16 AM
domain58's Avatar
It's amazing that from your photos the front fender is in such poor condition, can't imagine anyone doing such a poor repair. Must have been a ton of bog (body filler) used to make it look half decent.
David Bruce.
  #48
Old 06-06-2020, 11:04 AM
David Bruce.
yes I was quite shocked when I saw it in person!
  #49
Old 06-06-2020, 01:13 PM
Welded the holes up will now dress them and straighten the panel up
Rear of front wing needed blasting ideally (yes yes you told me lol) you can see the lead filler work that was originally done
Filler work done by previous owner at some point on front
  #50
Old 06-12-2020, 02:17 PM
Not much progress this week, but I bought some modern 4 pot calipers which I’ll fit on the front
some pics of underneath
Voucher Boy (06-21-2020)
  #51
Old 06-13-2020, 12:04 PM
Calipers arrived today and they are huge! Came off a Citroen C2R2 Rally car just need to fabricate some mounting brackets and find a vented disc that fits! Any ideas? Only cost me £100 for the pair
Ill get a pic compared with the original callipers
  #52
Old 06-21-2020, 05:28 AM
No updates this week as been busy with other cars, front wing has been ordered and will be here Tuesday hopefully so that should be fitted by the weekend at least
  #53
Old 06-23-2020, 02:26 PM
DaimlerMK2's Avatar
Disc you could use XJS
  #54
Old 09-13-2020, 12:44 PM
No real updates
new wing has arrived still haven’t fitted it though
  #55
Old 09-17-2020, 12:11 PM
Before I bought the mk1 the previous owner unfortunately had the rear axle stolen which was disc brake type, the current axle is drum
I’ve been searching the dreaded evilbay and hadn’t come across much at decent money until last night when a pair of front and rear axle assemblies at the right money came up so an offer was made and was accepted!
Bargain at £125 and only 40 mins away so will collect Sunday, this means I can refurbish these and still keep the mk1 rolling and get a disc rear axle back on, and make some brackets for some modern alloy calipers which will make it stop better (I hope lol) in line with more modern cars
The following 2 users liked this post by notenoughtime:
S-Type Owner (09-19-2020), Voucher Boy (09-17-2020)
  #56
Old 09-18-2020, 12:28 PM
Thats a really good fine, the MK2 jag rear axle is wider than the MK1 which helps with the handling, the only problem from what I understand is that it can cause a problem with the spats but if you arn't going to have them its meant to transform the handling.
If you also have the MK2 front subframe its worth looking at the differences as I have a feeling the suspension geometry was improved on the front of the Mk2 over the Mk1.
There is a bit about it here: https://www.jaguarforums.com/forum/m...bility-170839/
  #57
Old 09-18-2020, 05:08 PM
Glyn M Ruck's Avatar
Received 1,463 Likes on 1,135 Posts
I mentioned the wider rear track with pic in post 10 of this thread. The Mk1 rear track was troublingly narrow and adversely affected handling..
  #58
Old 09-20-2020, 12:41 PM
I don’t think the body is any narrower as the bumpers fit both cars, I was planning to just for some wide wires to the mk1 axle but the axle does sit much further in, I’ll also run Combe style arches of some sort so no drama with rubbing
for the money it’s not worth messing around so these can be blasted painted and I can make the correct brackets as I said for the brake calipers, Xjs discs have arrived and I’ve also found a XJR6 engine for reasonable money
  #59
Old 09-20-2020, 12:52 PM
If you are going for Coombs arches & don't want to fit a Mk2 axle I guess you could use some hubcentric spacers.
  #60
Old 09-20-2020, 01:06 PM
I’m going to got the mk2 axle as it saves work in the one run, I’ll fit the lsd and possibly xj6 rear calipers if not some nice alloy ones off something else
Glyn M Ruck (09-20-2020)
Quick Reply: Mk1 build
