MK2 3.8 Moss Gearbox Observation Hole
Jagfixer " Don't know of a plug. This is where you set the timing."
I thought that was on the lower side where there is a cover to be rotated over the hole if I recall correctly. Seems odd that there would be an open hole all of the time. That is big enough for a whole family of mice to move in :-)
Lin
Lin
just a thought because I could be wrong, but I think what is missing there is a plastic "grille", or a "vent grille" if you will. Could be a "Breather Vent hole".
The reason I say that is because I have seen Borg Warner transmissions used in Jaguar, which have a similar opening on the bell housing although on a different location, the BW66 for example, it has two similar rectangular holes at 6:00 o'clock where two vent grilles snap on.
so if you cannot find the proper part, you might get one from say, a BW66 tranny and trim it to fit.
