MK2 after all
The engine number should be down by the oil pressure sender unit on the carburettor side of the engine, it can be a bit hard to see with it all assembled. If it is an LA engine then they would generally have a steel sump rather than the later alloy one. I think they also have a scroll thrower on the rear of the crank rather than the rope seal but of course you can't see that with the gearbox and flywheel in place :-)
I think someone has had that plate stamped as the gearbox number looks too long for the plate and also an LA engine number would be for a much earlier 3.8.
As mentioned above a heritage certificate will confirm what numbers it had originally but of course it doesn't really matter as long as your happy with it.
It is but LA went from 1959 to early 1960's, the sequence for 3.8 MK2's went LA, LB, LC, LD, LE, I think a 1967 car would have been LE orginally. My 1959 MK2 3.8 originally had an LA engine but now has an LB engine which still has the steel sump.
If you go to this website you can search for your chassis number +/- say 1000 cars and see what engine numbers car of a similar age had:- SALOON Data - The Cars - Jaguar, Daimler classic saloon (sedan) information, articles, photos and register
Thanks, I have been searching there.
The whole this is a bit strange.
The chassis number is from a 3.4 because it is prefixed with an "E". E065816
The body number is in in the range for a 1966 manufactured 3.8 LHD.
The engine number is a 1960 3.8
The gearbox number is from a XJ6
So I guess a 3.8 body could have been put on a 3.4 chassis with an engine from a 1960 3.8 and the gearbox of an XJ6?
If it's all been done well which it certainly looks like it is I guess there is no real problem. One hassle is that the dutch car registration authority has it as a 3.4 (I assume from the chassis number) which is always going to be awkward if I need to sell it.
At least someone was honest enough to put this all on the VIN plate.
Received 1,488 Likes
It's strange because it is a monocoque body rather than body on chassis thus the numbers should tie up. Body number & Car number are different.
This is an example of a screened plate that has been changed and not an original etched plate.
I was just going to ask if the body and chassis could be separated. I might be over thinking this. My main worry it that it is registered as a 3.4 because of the chassis/body number. Does seem odd that these two don't match up. When I decode the Car Number it comes up as a 3.8 LHD Manual without overdrive just to make it even more confusing.
The chassis number should also be stamped into the bonnet landing panel and I recall that the body number might be on a plate under the rear bumper on a car of that year. On my 1959 car its on a plate behind the battery but my 1967 car has in behind the bumper.
The body is a monocoque construction and so doesn't have a seperate chassis.
One other thing is that the chassis plates for the MK2's are usually on the inner wing (exhaust side) and mounted upside down to make them easier to read when you lean over the wing. Not sure if there were in a different place on cars with power steering. Where its shown in your photo is where they were on the S-Type I believe. Might be different though on LHD cars.
#28
I'm fairly sure that the number stamped by the bonnet lock should be the chassis number and not the body number, someone might have stamped this number in here to try and make the car numbers align.
The heritage trust are the only way to find out what the numbers all mean and how they do or don't relate to each other, be careful though that you don't open a can of worms for yourself with this, its one thing for the engine and gearbox to be changed but something different for the body and chassis number to change as really on one of these they can't as body and chassis are one.
Glyn M Ruck (03-03-2024)
#30
#31
#32
It might also be worth contacting the heritage trust and see if they will give you the information you need if you send them a photo of the numbers and pay for a heritage cert. They did this for me with one of mine but that was back in 2011. If you explain the issue they might be willing to help, they might at least be able to confirm whether the body and chassis numbers do match. While its probably extremely unlikely there is no technical reason why Jaguar couldn't have used a 3.4 body to build a 3.8 if they had no 3.8 bodies as they are the same. It depends at what point the numbers were allocated to the bodys and if they came from the body manufacturers with the number on them.
The following 2 users liked this post by Homersimpson:
Cass3958 (03-03-2024),
#33
Thanks. I have not paid anything yet but in NL a verbal contract is binding. Having said that if the car is not what it appears to be that shouldn't be an issue.
I tried to get a cert from the heritage trust but you need to be the owner. I will contact them, maybe they are willing to help.
#34
#35
#36
#37
#38
#39
Thanks for the support guys it’s really appreciated. I have written to the heritage trust, hopefully they can help me get clarity. I think the guy selling is genuine, he has had the car for 7 years and really looked after it. I just don’t want any problems with the authorities and maybe end up with a car I am not allowed to drive and only has scrap value.
#40
