Mk2 anti roll bar
I tried to install the Harvey Bailey bar on my front end but would not fit between the oil pan and steering rack. Instead I used one off a later S-type which was thicker than stock but not as thick as the HBE one. It helped the front end roll a bit, but I currently have the old rubber bushings on the drop links, I'm hoping once I replace those with poly bushes it'll make a big difference. I also lowered the car 1" and replaced all front bushings with poly, so it's part of a system, not just a single mod done on it's own.
Have a look at this https://www.jaguarforums.com/forum/m...on-bar-187235/
and this
https://www.jaguarforums.com/forum/m...4/#post1533411
and this
https://www.jaguarforums.com/forum/m...ll-bar-127173/
hopefully that helps a little.
and this
and this
