mk2 coupe
Dave, I assume this is the Daimler? I like the coupe profile a lot. The front window frame extension should be pretty simple - simply braze a channel extension forward of the rear vertical piece and rechrome. Not sure what you're planning for the rear - fixed glass? If you go that route I'd recommend sourcing some mile steel channel that comes close to original profile - that way you can weld which is a lot easier than a torch. Keep us posted on your progress and hang in there - you have a lot of work ahead of you.
