My S-Types
#61
Major Progress
First to answer hellfish's question. (Thanks as you have prompted me to visit the Forum again...it has been a few years!) "I'm curious. Why did you shorten the body by 9" rather than extend the front doors a few inches and weld up the rear? That would seem easier." Of course it would have been easier but it doesn't look right proportionately. I've seen the red car and I don't see the point in it. By the way it sold on Barrett Jackson last month for less than $30k. Very disappointing. I wanted something different that nobody else has. I think it looks better proportionately by shortening it and now it is a true 2 door coupe. I have many picture of progress...so now I have to remember how to post them...picking up from where I left off 2 years ago.
#62
Frame Beefup
The floor was rusted and had to be fixed so I cut it all out. This led to me putting gussets inside the frame rails and capping the existing (solid but dented) frame rails. I had 14 gauge U channels made up for the straight sections, and made plates for the front kick-ups and rear where the frame widens. I added strenghtening or crush tubes inside the rails where the transmission mount bolts pass through.
#63
#64
Firewall remake.
Next came the firewall to fix the holes and make room for a Chevy V-8. Eliminated battery tray area and sloped the side on the passenger side. I forgot to mention before all this, I made engine mounts using the stock frame perches. I used a front engine mount plate from Speedway but there wasn't room for side mounts and cushions. I also bought a Trans cross member and modified it. I'm rather proud of the engine mounts. I incorporated mounts to connect to the suspension cross-member and hold it rigidly. Additionally I put bushings in the front sandwich plates and welded plates to the Vee mounts. Now the whoile front suspension is rigid. More on this later.
#65
Floors and Trans Tunnel
I crated the transmission tunnel first knowing it would be the hardest part. I found a local shop with a bead roller to put strengthening ribs in the floor sheets. Lots of measuring, paper templates and numerous fitment sessions. Between the frame rails and flooring I must have made 1,000 spot welds...and of course had to grind it all smooth. Very tedious and long hours.
#66
#67
Drivers side of firewall
The stock brake pedal setup just wasn't going to cut it. I didn't want to use the complex original booster setup and pedals (for brake and clutch). So I bought a pedal box from Speedway motors and built the framework and a dog house for them. At the same time I cut out the upper firewall and put in a new one.
The following 2 users liked this post by Fla Steve:
58mk1x2 (02-15-2015),
lickahotskillet (02-18-2015)
#68
JagRod
By the Way. I sold the "Nice" S-Type. I just didn't want to sink a ton of money restoring it while also building the coupe. I refer to the cut-up car as my Jag Rod but if I change the title of my thread I may lose you guys that are following this...?? Many more pics to come. I've completely rbuilt the front and rear suspension. Utilized 1990 XJS uprights/spindles and 4 piston calipers. The rear is really going to be cool to...stay tuned.
MK2 (02-12-2015)
#69
#70
#72
Continued on new thread
To my friends who were following my progress; I started a new post in this Forum. The link to it is here:
https://www.jaguarforums.com/forum/m...1/#post1822025
Titled "Jag Rod S Type 2 door Coupe"
Hope you tune back in. BTW. The reason for the delay....I spent over a year totally gutting and rebuilding my 1989 Sea Ray; 24ft cuddy cabin. All new stringers, sub-floor and main deck. Swapped the Alpha out-drive for the HD Bravo to handle the power from the new 383 CI Stroker motor. Went from stock 260HP to 450HP!!!!! Haven't had a chance to find the new top end speed yet.
3jagfamily
10-01-2015 01:49 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
